AutoCAD Civil 3D 2017 fails to install
I am trying to install C3d 2017 on Windows 10.
The error message I am getting is "An error occurred while installing this product.  For more information view the installation log file."
Below is the install log.
Any help is greatly appreciated.
Randy
2017/1/26:10:51:56 rtompkins RANDYASUS === Setup started on RANDYASUS by rtompkins ===
2017/1/26:10:51:56 rtompkins RANDYASUS Path_Length: 162
2017/1/26:10:51:56 rtompkins RANDYASUS Current Directory D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm
2017/1/26:10:51:56 rtompkins RANDYASUS Launch
2017/1/26:10:51:56 rtompkins RANDYASUS CommandLine
2017/1/26:10:51:56 rtompkins RANDYASUS Current Directory C:\Users\RTOMPK~1\AppData\Local\Temp\_AI3BC.tmp
2017/1/26:10:52:14 rtompkins RANDYASUS === Setup ended ===
2017/1/26:10:52:00 rtompkins RANDYASUS === Setup started on RANDYASUS by rtompkins ===
2017/1/26:10:52:00 rtompkins RANDYASUS Path_Length: 162
2017/1/26:10:52:00 rtompkins RANDYASUS Current Directory C:\Users\RTOMPK~1\AppData\Local\Temp\_AI3BC.tmp
2017/1/26:10:52:00 rtompkins RANDYASUS Launch
2017/1/26:10:52:00 rtompkins RANDYASUS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\RTOMPK~1\AppData\Local\Temp\_AI3BC.tmp\Setup\AcSetup.dll
2017/1/26:10:52:00 rtompkins RANDYASUS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/26:10:52:14 rtompkins RANDYASUS PageOpen LaunchDialog
2017/1/26:10:52:50 rtompkins RANDYASUS PageOpen LicenseDialog
2017/1/26:10:52:53 rtompkins RANDYASUS PageOpen ProductInfoDialog
2017/1/26:10:52:53 rtompkins RANDYASUS PageOpen ProductSelectionDialog2
2017/1/26:10:53:13 rtompkins RANDYASUS PageOpen FullProgressDialog
2017/1/26:10:53:13 rtompkins RANDYASUS Installing Universal C Runtime (KB3118401): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/26:10:53:13 rtompkins RANDYASUS Install Universal C Runtime (KB3118401) Succeeded
2017/1/26:10:53:13 rtompkins RANDYASUS Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\RTOMPK~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/26:10:53:14 rtompkins RANDYASUS Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/1/26:10:53:14 rtompkins RANDYASUS Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\RTOMPK~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/26:10:53:15 rtompkins RANDYASUS Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/1/26:10:53:15 rtompkins RANDYASUS Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/26:10:53:28 rtompkins RANDYASUS Install DirectX Runtime Succeeded
2017/1/26:10:53:28 rtompkins RANDYASUS Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2017" SETUP_PACKAGECODE={A4C298A0-28A8-44ED-A826-A4CDE4965DA2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={530E618F-2F2E-46A6-8AA1-5B506A02F4C5} ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/26:10:53:28 rtompkins RANDYASUS Install Autodesk Material Library 2017 Failed Installation aborted, Result=1603
2017/1/26:10:53:28 rtompkins RANDYASUS Rollback DirectX Runtime Failed Failure is ignored, Result=1603
2017/1/26:10:53:35 rtompkins RANDYASUS PageOpen InstallCompleteDialog
2017/1/26:10:55:05 rtompkins RANDYASUS === Setup ended ===
2017/1/26:10:55:07 rtompkins RANDYASUS === Setup started on RANDYASUS by rtompkins ===
2017/1/26:10:55:07 rtompkins RANDYASUS Path_Length: 162
2017/1/26:10:55:07 rtompkins RANDYASUS Current Directory D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm
2017/1/26:10:55:07 rtompkins RANDYASUS Launch
2017/1/26:10:55:07 rtompkins RANDYASUS CommandLine
2017/1/26:10:55:07 rtompkins RANDYASUS Current Directory C:\Users\RTOMPK~1\AppData\Local\Temp\_AIF026.tmp
2017/1/26:10:55:13 rtompkins RANDYASUS === Setup ended ===
2017/1/26:10:55:08 rtompkins RANDYASUS === Setup started on RANDYASUS by rtompkins ===
2017/1/26:10:55:08 rtompkins RANDYASUS Path_Length: 162
2017/1/26:10:55:08 rtompkins RANDYASUS Current Directory C:\Users\RTOMPK~1\AppData\Local\Temp\_AIF026.tmp
2017/1/26:10:55:08 rtompkins RANDYASUS Launch
2017/1/26:10:55:08 rtompkins RANDYASUS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\RTOMPK~1\AppData\Local\Temp\_AIF026.tmp\Setup\AcSetup.dll
2017/1/26:10:55:08 rtompkins RANDYASUS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/26:10:55:13 rtompkins RANDYASUS PageOpen LaunchDialog
2017/1/26:10:55:18 rtompkins RANDYASUS PageOpen LicenseDialog
2017/1/26:10:55:18 rtompkins RANDYASUS PageOpen ProductSelectionDialog2
2017/1/26:10:55:28 rtompkins RANDYASUS PageOpen LicenseDialog
2017/1/26:10:55:28 rtompkins RANDYASUS PageOpen LaunchDialog
2017/1/26:10:56:01 rtompkins RANDYASUS PageOpen LicenseDialog
2017/1/26:10:56:05 rtompkins RANDYASUS PageOpen ProductInfoDialog
2017/1/26:10:56:05 rtompkins RANDYASUS PageOpen ProductSelectionDialog2
2017/1/26:10:57:49 rtompkins RANDYASUS PageOpen FullProgressDialog
2017/1/26:10:57:49 rtompkins RANDYASUS Installing Universal C Runtime (KB3118401): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/26:10:57:49 rtompkins RANDYASUS Install Universal C Runtime (KB3118401) Succeeded
2017/1/26:10:57:49 rtompkins RANDYASUS Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\RTOMPK~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/26:10:57:50 rtompkins RANDYASUS Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/1/26:10:57:50 rtompkins RANDYASUS Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\RTOMPK~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/26:10:57:50 rtompkins RANDYASUS Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/1/26:10:57:50 rtompkins RANDYASUS Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/26:10:58:00 rtompkins RANDYASUS Install DirectX Runtime Succeeded
2017/1/26:10:58:00 rtompkins RANDYASUS Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2017" SETUP_PACKAGECODE={A4C298A0-28A8-44ED-A826-A4CDE4965DA2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={530E618F-2F2E-46A6-8AA1-5B506A02F4C5} ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/26:10:58:00 rtompkins RANDYASUS Install Autodesk Material Library 2017 Failed Installation aborted, Result=1603
2017/1/26:10:58:00 rtompkins RANDYASUS Rollback DirectX Runtime Failed Failure is ignored, Result=1603
Mark.Lancaster
@Anonymous
Your installation is failing when its trying to install the material libraries.  I would suggest installing them manually per this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-uninstall-and-reinstall-Autodesk-Material-Library.html and then try your installation again.  Just make sure to adjust folder names because this article was written for the 2016 version.  Is the "D" drive you are running the installation from a hard drive partition on your machine or on the network?  One final question..  Where did you get the installation files from?  Autodesk Account/Install now, download manager or Autodesk Virtual Agent?
Mark Lancaster
rkmcswain
Are you running a silent install?
Error 1638 means that another version of the product is already installed. The installs for Microsoft Visual C++ 2015 Redistributable (x86) are generating this error per your log.
I see some 1603 errors in there too, which could mean a whole lot of things.
Are you getting the verbose log file in the client machines %temp% folder?
Also, you might check the event viewer on the client machine. It might reveal more detail about the 1603 error.
Mark.Lancaster
@rkmcswain
Good catch..  I missed the 1638 error in the log...  Smiley Wink
Mark Lancaster
Comments:
I have currently installed on this machine:
AutoCAD C3d 2009
Land Desktop 2009
Autocad C3d 2015
Autocad Trueview 2014
The main hard drive is separated into 2 partitions, C and D.  So to clarify, D is local, not network.
I downloaded the install from download manager.  I never try to install something like this directly over the net.
No, i am not doing a silent install.
I am not sure which verbose log file you are looking for.
here is one for the materials library
=== Verbose logging started: 1/26/2017 10:58:00 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Users\RTOMPK~1\AppData\Local\Temp\_AIF026.tmp\Setup.exe ===
MSI (c) (5C:60) [10:58:00:380]: Resetting cached policy values
MSI (c) (5C:60) [10:58:00:380]: Machine policy value 'Debug' is 0
MSI (c) (5C:60) [10:58:00:380]: ******* RunEngine:
******* Product: D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\Content\ADSKMaterials\2017\CM\MaterialLibrary2017.msi
******* Action:
******* CommandLine: **********
MSI (c) (5C:60) [10:58:00:381]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (5C:60) [10:58:00:381]: Grabbed execution mutex.
MSI (c) (5C:60) [10:58:00:383]: Cloaking enabled.
MSI (c) (5C:60) [10:58:00:383]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (5C:60) [10:58:00:384]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (84:A4) [10:58:00:390]: Running installation inside multi-package transaction D:\Autodesk\AutoCAD_Civil3D_2017_English_Win_64bit_dlm\Content\ADSKMaterials\2017\CM\MaterialLibrary2017.msi
MSI (s) (84:A4) [10:58:00:390]: Grabbed execution mutex.
MSI (s) (84:F4) [10:58:00:392]: MainEngineThread is returning 1603
MSI (s) (84:A4) [10:58:00:393]: User policy value 'DisableRollback' is 0
MSI (s) (84:A4) [10:58:00:394]: Machine policy value 'DisableRollback' is 0
MSI (s) (84:A4) [10:58:00:394]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (84:A4) [10:58:00:394]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (84:A4) [10:58:00:397]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (84:A4) [10:58:00:398]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (5C:60) [10:58:00:400]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (5C:60) [10:58:00:401]: MainEngineThread is returning 1603
=== Verbose logging stopped: 1/26/2017 10:58:00 ===
Hi Mark,
I tried your suggestion.
When I went to the uninstall, it only shows 2015 programs, nothing from 2017.
Then I try to install the first Material Library manually as specified and it gives me an error.
Autodesk Meterial Library Library 2017 Setup Wizard ended prematurely because of an error.  Your system has not been modified.
Thanks for your assistance.
Randy
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
