Installation & Licensing
AutoCAD Civil 3D 2015 has C++ failure upon launch
2 REPLIES 2
482 Views, 2 Replies
2020/7/28:14:58:40 PP00001763 LBHAR0182 === Setup started on LBHAR0182 by PP00001763 === 2020/7/28:14:58:40 PP00001763 LBHAR0182 Path_Length: 152 2020/7/28:14:58:40 PP00001763 LBHAR0182 Current Directory F: 2020/7/28:14:58:40 PP00001763 LBHAR0182 Launch 2020/7/28:14:58:40 PP00001763 LBHAR0182 CommandLine 2020/7/28:14:58:40 PP00001763 LBHAR0182 Path_Length: 152 2020/7/28:14:58:40 PP00001763 LBHAR0182 Current Directory C:\Users\PP0000~1\AppData\Local\Temp\_AIC5F2.tmp 2020/7/28:14:59:02 PP00001763 LBHAR0182 === Setup ended === 2020/7/28:14:58:51 PP00001763 LBHAR0182 === Setup started on LBHAR0182 by PP00001763 === 2020/7/28:14:58:51 PP00001763 LBHAR0182 Path_Length: 152 2020/7/28:14:58:51 PP00001763 LBHAR0182 Current Directory C:\Users\PP0000~1\AppData\Local\Temp\_AIC5F2.tmp 2020/7/28:14:58:51 PP00001763 LBHAR0182 Launch 2020/7/28:14:58:53 PP00001763 LBHAR0182 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PP0000~1\AppData\Local\Temp\_AIC5F2.tmp\Setup\AcSetup.dll 2020/7/28:14:58:53 PP00001763 LBHAR0182 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2020/7/28:14:59:02 PP00001763 LBHAR0182 PageOpen LaunchDialog 2020/7/28:14:59:06 PP00001763 LBHAR0182 PageOpen LicenseDialog 2020/7/28:14:59:17 PP00001763 LBHAR0182 PageOpen ProductInfoDialog 2020/7/28:14:59:54 PP00001763 LBHAR0182 PageOpen ProductSelectionDialog2 2020/7/28:15:00:26 PP00001763 LBHAR0182 PageOpen FullProgressDialog 2020/7/28:15:00:26 PP00001763 LBHAR0182 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "F:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\PP0000~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2020/7/28:15:00:31 PP00001763 LBHAR0182 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2020/7/28:15:00:31 PP00001763 LBHAR0182 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "F:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\PP0000~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2020/7/28:15:00:33 PP00001763 LBHAR0182 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2020/7/28:15:00:33 PP00001763 LBHAR0182 Installing DirectX Runtime: "F:\3rdParty\DirectX\DXSETUP.exe" /silent 2020/7/28:15:00:47 PP00001763 LBHAR0182 Install DirectX Runtime Succeeded 2020/7/28:15:00:47 PP00001763 LBHAR0182 Installing SQL Server CE 4.0 x64: ADSK_EULA_STATUS=#1 MUILANG=zh-tw SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\PP0000~1\AppData\Local\Temp\_AIC5F2.tmp\Media.mst" 2020/7/28:15:00:56 PP00001763 LBHAR0182 Install SQL Server CE 4.0 x64 Succeeded 2020/7/28:15:00:56 PP00001763 LBHAR0182 Installing Microsoft Visual Basic Power Packs 10.0: "F:\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe" /q /l C:\Users\PP0000~1\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log 2020/7/28:15:01:01 PP00001763 LBHAR0182 Install Microsoft Visual Basic Power Packs 10.0 Succeeded 2020/7/28:15:01:03 PP00001763 LBHAR0182 Installing Autodesk® AutoCAD® Civil 3D® 2015: TRANSFORMS="F:\x64\zh-tw\C3D\C3D.mst;C:\Users\PP0000~1\AppData\Local\Temp\_AIC5F2.tmp\x64\C3D\C3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="D:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/7/28:15:10:16 PP00001763 LBHAR0182 Install Autodesk® AutoCAD® Civil 3D® 2015 Failed Installation aborted, Result=1601 2020/7/28:15:11:22 PP00001763 LBHAR0182 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619 2020/7/28:15:11:29 PP00001763 LBHAR0182 Rollback SQL Server CE 4.0 x64 Succeeded 2020/7/28:15:11:30 PP00001763 LBHAR0182 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2020/7/28:15:11:30 PP00001763 LBHAR0182 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2020/7/28:15:11:31 PP00001763 LBHAR0182 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
@Anonymous
Topic Title has been changed for better findability by @Tiana_Y
2 REPLIES 2
Jeff_M
Was there a question here?
Jeff_M, also a frequent Swamper
Civil3DReminders_com
Isn't Civil 3D 2015 no longer supported for install?
I think you'd need to make sure the computer has all it's Windows updates installed, restart, and download the troublesome c++ install from Microsoft. Note that Microsoft is killing old downloads, so you might not be able to find it.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Administrator Productivity
