AutoCAD 2023 installation error
Dazzman
Message 1 of 38
Dazzman
I'm receiving this error message if I try a local or deployment installation on our systems?
So far I've tried the installation on as fixed workstation and a laptop they are part of our standard system build and have the following installed
Windows 10 21H2
Office 365
Sophos Intercept X
AutoCAD 2018 & 2020
Other than that there is nothing special about them, has or is anyone else encountering the same issue?
Thanks.
Replies (37)
Message 21 of 38
Dazzman
I completely agree with what you are saying, I have been dealing with Autodesk products over 26 years and this is now the 5th time that I've discovered an issue that seems to have been missed in testing, with the responses back from the forum and even Autodesk being it's your problem and you need to sort it out.
I have been in the fortunate position of resolving 2 of these issues myself and then had Autodesk contact me for help, when others reported the same issues, at which point my response has been its you product you sort it out!
I have relented in the end and given them the resolution especially when our reseller called basically begging for the answer as they had 2 clients with the issue and not being able to fix it was making them look bad.
As for your problem are you able to run an elevated command/powershell prompt and type in whoami /priv
once it returns the list of privileges do you see that you have access to
SeBackupPrivilege (state Disabled)
SeRestorePrivilege (state Disabled)
I was unable to install the product until these showed on the local system.
Hope this helps.
Message 22 of 38
elgannaway
I just find it ridiculous that this is coming up after decades of selling & installing these products.  They have basically made it so only the systems admin (in the case of a corporate structure) can install software.  For AutoDesk to deny that this is a problem that they have caused is doubly ridiculous.  At this point, I guess I have to wait for our Systems Admin to install the new software or have my ID added to that category, or have the security setting for those policies changed to something other than Systems Admin (specific name of setting redacted)
Message 23 of 38
jpCADconsulting
FWIW, my issue with the deployment failing was that the deploy configuration process doe snot like mapped drive paths anywhere in the config. Not in the paths to the deployment folder, the log file or to the custom ARG file I had created.
Once I redid the precess using all UNC paths, it worked. This is a real pain as every time we need to upgrade the server or move the deployment, it has to be redone, but whatever. It's working.
Hope this helps some of you.
Message 24 of 38
mdavis22569
@elgannaway
Then on the otherside of:
You have IT and companies wanting that.  Control and not allowing Permissions.
So it's a damned if you do / damned if you don't.
Millions of installs a year ... not all of them will be perfect. Way to many variables.
Individuals shouldn't have any admin issues for their PC's.
Mike Davis
Message 25 of 38
ahmadjabir18
Community Visitor
Community Visitor
I have exactly the same problem, I tried everything, and the same keeps happening.
Disabling Windows Defender and other security Apps was worthless.
Note that I installed Autodesk Revit 2023 without any issue.
the problem is with Autocad only.
Message 26 of 38
Basam.Yousif
What method are you using? Autodesk offers three methods, of which TWO do not work! The browser download is the only way that works.
But before you do that, make sure your system is ready:
- Push all windows update and reboot
- Clear out the temp folders
- Clean out all remnants of previous install attempts (including uninstalling items)
- You might need to uninstall (not disable) anti virus
Message 27 of 38
b_lawgh
Hi So I was having the same error 4000 for a week. After inspecting the Logs at \AppData\Local\Autodesk\ODIS, I found out that some ODIS components at C:\ProgramData\Autodesk\ODIS and C:\Program Files\Autodesk\AdODIS could not be deleted by the installer automatically. Deleted these folders and AutoCAD installed just fine.
Message 28 of 38
seb.reid
This has just fixed my problem. The service which runs in that folder "autodesk Access Service Host" in the delivery application, has been blocking my installations. Stopping that service, deleting these folders, has allowed me to do a clean install again!
Thanks @b_lawgh
Message 29 of 38
whsam89
Community Visitor
Community Visitor
i tried installation after deleting the folders & files in the C:\ProgramData\Autodesk directory, it works😀
Message 30 of 38
Willjoe2442
Right-click on Autocad or Autodesk programs one by one and choose Uninstall to uninstall them. After removing all the Autodesk elements, restart your computer. Install the Autodesk product, which will be installed as a fresh installation without the error “AutoCAD is already Installed”
Will
Message 31 of 38
eduardovbonfim
Observer
Observer
I usually dont enter in the forum to reply but man, you're a life savior, thank you it worked for me.
Message 32 of 38
andrew.perry8
We tried a number of different ways to get around this problem for us. I tried changing the date as per https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/simplecontent/content/autocad...
then uninstalled sophos, and then logged on as the local administrator.
Local administrator may not have been required, but I had to disconnect from the network so the domain wouldn't constantly put the time back to the right time, and we have roaming profiles, so the temporary location couldn't be found.
Coworker has just reported that he managed to install on his workstation by just changing the date to the 1st of march. He also had to change the date for the update to work. AutoCAD 2023.1 Update 64-Bit
Message 33 of 38
cdodge
Hey Folks.   If anyone runs into this issue again, try this script I wrote and report back.
It basically does a CLEAN uninstall of the new Autodesk ODIS installer engine, downloads the latest version and installs.   So I believe it should resolve the issue based on several of the reported solutions.
 RESET_ODIS_INSTALLER.BAT
I would guess any system date rollback solutions needed are the result of some aggressive security group policy or Antivirus preventing old versions of Autodesk ODIS installer files from running or updating themselves automatically.  Maybe due to expired digital signatures of some of those files?
Chris Dodge
Microdesk
Message 34 of 38
ahmedeid446
Community Visitor
Community Visitor
can you please tell the steps of the solution
Message 35 of 38
msrom
Fantastic message. I quit asking for help from Autodesk since 1990's. No time for bull ****.
Message 36 of 38
iqramakasim
Community Visitor
Community Visitor
I have the same problem, I have tried installing it on several machines and I get the same error. Out of 5 machines i was only able to install it on one machine.
Message 37 of 38
rushabhthakkar_910
@iqramakasim, Have a look at this..!!
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 38 of 38
Faraz_farhad
Community Visitor
Community Visitor
I know it was about a year ago, but I wanted to tell you: thanks Dazzman. It helped me a lot by understanding that this problem is only for 2023. I installed the 2022 AutoCAD and I didn't have any problem with it. However I am still searching to find a solution for installing 2023!
