Autocad 2022 Installation Error
rushabhthakkar_910
rushabhthakkar_910
Hello Everyone,
A few hours ago, I unistalled Autocad 2018 Educational Version with Autodesk Uninstall Tool.
And than requested for Autocad 2022 Educational License and Downloaded the Setup file.
And after downloading it in E-Drive, and running the Setup, I get the Below error...
Whereas I don't see Autocad 2022 Installed anywhere on my Laptop. What should I do about this.
Any help on this..??
Search results of my Laptop..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Replies (26)
rushabhthakkar_910
Can anyone help me out with this..??
@Tiana_Y@amanda.k@leowarren34, @pendean, @mdavis22569 ...
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
Hi @rushabhthakkar_910
Run the Microsoft FixIt tool.
Then try again...
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
I would also recommend downloading a new full installer ...
Mike Davis
amanda.k
Hello @rushabhthakkar_910 ,
@mdavis22569 is correct - for this error we suggest following the AKN article here: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Produc.... The first step is to run the Microsoft FixIt tool.
Please follow the instructions on that article and let us know how it goes!
Amanda
Amanda Pruyn
Senior Program Manager, Community
rushabhthakkar_910
Thank You @amanda.k and @mdavis22569 for your replies..
After using the Microsoft FixIt tool, the installation began. Which relieved me for a while..
But than this error came after installation was almost completed by 90-95%..
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
Hi
Take a look at the following
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal....
Mike Davis
rushabhthakkar_910
Thanks a lot @mdavis22569 for your responses.. I really appreciate it.
But my only worry is I do not uninstall any Application that is not intended too.. So can you have a look at this Screencast Video..?
(https://autode.sk/3IObGiN) And help me with what all I have to Uninstall with the Microsoft FixIt tool..?
Thanks and Regards,
Rushabh Thakkar.
rushabhthakkar_910
@mdavis22569 and @amanda.k,
Do I have to uninstall..? I mean after installing and running it, if it were supposed to be uninstalled, why did I install it..?
 I mean is this the correct procedure..? Cause I am currently on the Red Arrow marked step in the below Image. And should I proceed ahead with Uninstalling Single Sign-On..?
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
You're not uninstalling all of the program ... just that one part of the installation.
Mike Davis
rushabhthakkar_910
Even after performing all the said steps, still I am getting this Error..
What should I do now..?
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
I would look at the how do I fix this ...
From there:
Clean out the %temp% folder
 Download and install these 2 things first:
Autodesk Licensing Service -win-11.1.0.5629 installer file.
https://download.autodesk.com/us/support/files/autodesk-licensing-service-update/win/adsklicensingin...
We also want this update:
Autodesk Single Sign On Component 2020.1:
https://up.autodesk.com/2020/ADSSO/A97BF60C-1A84-42CF-865F-FADC3E0E8DBA/AdSSO.msi
Download this installer:
https://efulfillment.autodesk.com/NetSWDLD/2022/ACD/1E7D4EF7-A28E-3D3E-BA3C-C6FAE4AAB2E0/SFX/AutoCAD...
Make sure your anti-virus is off...
Mike Davis
rushabhthakkar_910
And should I delete the Setups that I downloaded...
And download a new one from the link you share..
Actually this is my worst fear while using any Engineering software that it won't install.. and nothing like this has happened with me in any other Autodesk Product.
So this is a bit new for me. So I hope you understand if i might ask some silly questions.. 😅
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
Yes .. everything I shared .. I'd like to try
Mike Davis
rushabhthakkar_910
Again the same error has come.
But this time I don't know why after reaching 90-92%, the installation suddenly started falling instead of increasing..
i.e the figure started moving from 92 and dropped to 69% before the error appeared.. 🤷
Link to the video saved in Google Drive due to size restrictions.. (https://drive.google.com/file/d/122vhkhEG_LEMt7cLvd7d9LLCt2XG6LBr/view?usp=drivesdk)
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
Do you have Admin rights on this PC?
Also, any other Autodesk Software installed?
Can you tell me more about your PC?
OS / Ram / CPU / GPU?
Mike Davis
pendean
Community Legend
Community Legend
rushabhthakkar_910
The System is my Personal Laptop. So you can say that I have the Admin rights..
And it is a Core i5 8th Generation, 8GB Ram, 1TB HDD Storage, 2GB Nvidia Graphics card Laptop.
And there are other Autodesk Softwares installed i.e Fusion 360, Inventor, Maya, VRED.
And a few days back I had AutoCAD 2018 too which I uninstalled and tried Installing 2022 when the error came..
Thanks and Regards,
Rushabh Thakkar.
rushabhthakkar_910
@pendean, I'll share the files in a while as I am currently at work..
Thanks and Regards,
Rushabh Thakkar.
mdavis22569
What OS?
Mike Davis
mdavis22569
What OS?
Mike Davis
