AUTOCAD 2021 NOT OPENING ON WINDOWS 10
Message 1 of 47
HI i recently installed Autocad 2021 from its official website, after i followed all installation procedures, and after having an installation sucessfull notice, the app just doesnt open.
The cursor changes to loading and then stop.It just doesn not open..
Can somebody please help me
Thank you
Replies (46)
Message 2 of 47
mdavis22569
What video card and driver do you have?
What Anti-Virus / Firewall do you have?
Do you have any other Autodesk software on the PC, if so what?
Mike Davis
Message 3 of 47
HII, i used to have autocad 2018 befor 1 reset my laptop. Its an Hp notebook running on Nvidia 1050 graphic card
Message 4 of 47
I even tried with Autocad 2019, same issue
Message 5 of 47
mdavis22569
Do you know the driver on the GTX1050
They aren't certified and when some of the newer drivers are installed they have an issue.
Can you try this driver:
NVIDIA DRIVERS GeForce Game Ready Driver WHQL
Mike Davis
Message 6 of 47
I have nvidia mx130 on my laptop. My brother has simple intel graphic card and he is able to run autocad but I am not.
Also my firewall is managed by McAfee Livesafe.
Please help me out.
Message 7 of 47
pendean
Community Legend
Community Legend
Disable McAfee for a period of time and test AutoCAD again, any changes?
Message 8 of 47
mdavis22569
The MX130 isn't certified either .. just an FYI. I've seen better with the Intel than the wrong drivers on the GTX's that why I suggested it
And  I would disable the McAfee like Dean mentioned
Mike Davis
Message 9 of 47
Done but still the same problem.
Message 10 of 47
mdavis22569
What video card is the current card?
Mike Davis
Message 11 of 47
Nvidia mx130
Message 12 of 47
mdavis22569
Try this
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/starting-a...
But I would also try an older version.. see if this card can work with it
Mike Davis
Message 13 of 47
no it didn't work.
Message 14 of 47
mdavis22569
Older versions aren't working either?
Mike Davis
Message 15 of 47
No
Message 16 of 47
mdavis22569
You likely have a PC side related issue vs Autodesk issue.
If it was one version I might go with it..but if nothing is working.
Uncertified video cards.
McAfee running ...
I'm looking at the PC as the issue.
Might try here first:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinst...
Mike Davis
Message 17 of 47
No it didnt work
Message 18 of 47
Installation went fine, but not opening AutoCAD 2021.
I've RTX 2060 video card and No McFee antivirus.
Any help would be appreciated..
Message 19 of 47
kevin
Hi, have just installed 2021 AutoCad. It worked initially(1 day) but now it will not load. The program starts then after approx.3 seconds disappears off the screen.
I have repaired and re-installed it about 1 million times but still no luck. Inventor, Revit LT Fusion360 (downloaded at the same time), all work fine. Any suggestions greatly welcomed
Thank you
Message 20 of 47
kgbalakumar92
Community Visitor
Community Visitor
Exactly same problem
