autocad 2019 windows
This widget could not be displayed.
I recently downloaded and installed autocad2019 but I couldn't locate the app, so i had to uninstall it. can you help me download, install and locate agan? thank you
Accepted solutions (4)
Replies (7)
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
Welcome to the community!
I would suggest using AVA to download the installer and then review these installation instructions.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
I am still having troubles with the newly installed autocad 2017 on macOS Mojave. Please help me. Its urgent
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
Thanks for the reply. The focus of this thread started as installing AutoCAD 2019 on Windows.
AutoCAD for Mac 2017 requires the 2017.3 update for Mojave compatibility. Please see this article.
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
thank you for your help, it worked. But i have another issue. The flatten command is not working. how can i fix it?
Mark.Lancaster
@Anonymous
This forum is only for installation and licensing issues.  You are asking a question about a command/function inside of AutoCAD.  Please use the AutoCAD forum to ask about your flatten command issue.
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
Mark Lancaster
