I used the program to analyze the problem, and then followed the instruction stated below to restart the computer, after restarting and running install, it gave me the same problem.
How do I fix this problem to install AutoCAD 2018?
Error Analysis Component:
Autodesk® AutoCAD® 2018 Core
Error Name:
Detected an instance of AutoCAD running
Suggested Resolution:
It appears that you have a running instance of AutoCAD on your system, which may include cached files for Quick Launch of AutoCAD.
Please reboot your system and try the installation again.
Additional Installation Help
If the recommendation above did not resolve your issue, or if you have additional questions, please feel free to reach out to Autodesk Support directly via our contact us page. In addition, Autodesk experts are now monitoring and responding in the Install & Licensing Autodesk Discussion Forum. For fast answers to your questions from Autodesk and community experts, please visit the forum by clicking here
Log Files
Setup Log from Install Framework or Bundle
Autodesk Building Design Suite Premium 2018 Setup.log
Context of Error (from above Setup Log):
2017/6/6:13:40:50 NStanisheva WS-STHAPA-PC Installing Autodesk® AutoCAD® 2018 Core: TRANSFORMS="C:\Users\NSTANI~1\AppData\Local\Temp\_AI78E.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2018" SETUP_PACKAGECODE={000AE799-4817-4CF5-98E5-EE45D162D914} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={C928E4FC-B352-4E6E-BC69-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2018" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/6/6:13:42:59 NStanisheva WS-STHAPA-PC Install Autodesk® AutoCAD® 2018 Core Failed Installation aborted, Result=1603
2017/6/6:13:43:02 NStanisheva WS-STHAPA-PC Rollback Autodesk® Material Library 2018 - Advanced Image Library Succeeded
The following are the log files associated with the installer setup log (above), in reverse chronological order. The log file in red (if any) is the"most likely" cause of the installation failure
Please note, this HTML file will also be included in the zip file.
Log file last modified: Tue Jun 6 13:42:59 2017
exe_path=%platform%\acad\acad.msi
exe64_path=
exe_param=
autodesk autocad 2018 core install.log
Error occurs on line 9210 of log file (approximately)
Context of failure in Log file is as follows:
Expand Entire Error Context (HTML5 Browsers Only)
CustomAction CheckForRunningTasks returned actual e...
Collapse Entire Error Context
MSI (s) (F8:14) [13:42:58:895]: Doing action: CheckForRunningTasks
Action ended 13:42:58: DeleteERegData. Return value 1.
MSI (s) (F8:A0) [13:42:58:895]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI7115.tmp, Entrypoint: CheckForRunningTasks
Action start 13:42:58: CheckForRunningTasks.
Action start 13:42:58: CheckForRunningTasks. CustomAction CheckForRunningTasks returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 13:42:58: CheckForRunningTasks. Return value 3.
Log file last modified: Tue Jun 6 13:40:48 2017
exe_path=Content\ADSKMaterials\2018\AIL\AdvancedImageLibrary2018.msi
exe64_path=
exe_param=MSIFASTINSTALL
advancedimagelibrary2018.log
exe64_path=
exe_param=
Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric
Log file last modified: Tue Jun 6 13:39:01 2017
exe_path=x64\MEP_Fab\MEP_Fab_M.msi
exe64_path=
exe_param=
revit 2018 mep metric content v20 install.log
Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial
Log file last modified: Tue Jun 6 13:38:30 2017
exe_path=x64\MEP_Fab\MEP_Fab_I.msi
exe64_path=
exe_param=
revit 2018 mep imperial content v20 install.log
Autodesk® FormIt Add-in for Revit® 2018
Log file last modified: Tue Jun 6 13:38:14 2017
exe_path=x64\FormIt\FormIt360Converter.msi
exe64_path=
exe_param=
autodesk formit add-in for revit 2018 install.log
ContentPackUI.log
Log file last modified: Tue Jun 6 13:37:29 2017
exe_path=unknown
exe64_path=unknown
exe_param=unknown
contentpackui.log
cp_Install.log
Log file last modified: Tue Jun 6 13:37:05 2017
exe_path=unknown
exe64_path=unknown
exe_param=unknown
cp_install.log
Autodesk Material Library 2018 - Base Image Library
Log file last modified: Fri Jun 2 16:26:39 2017
exe_path=Content\ADSKMaterials\2018\ILB\BaseImageLibrary2018.msi
exe64_path=
exe_param=
materiallibrary2018cmilb.log
exe64_path=
exe_param=
Log file last modified: Fri Jun 2 16:26:33 2017
exe_path=Content\ADSKMaterials\2018\CM\MaterialLibrary2018.msi
exe64_path=
exe_param=
materiallibrary2018cm.log
exe64_path=
exe_param=
Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018
Log file last modified: Fri Jun 2 16:25:49 2017
exe_path=x64\DYN\DynamoRevit.msi
exe64_path=
exe_param=
autodesk dynamorevit add-in for revit 2018 install.log
Autodesk® DYNAMOCORE Add-in for Revit® 2018
Log file last modified: Fri Jun 2 16:25:16 2017
exe_path=x64\DYN\DynamoCore.msi
exe64_path=
exe_param=
autodesk dynamocore add-in for revit 2018 install.log
Autodesk Material Library 2018 - Low Image Library
Log file last modified: Fri Jun 2 16:23:43 2017
exe_path=Content\ADSKMaterials\2018\ILL\LowImageLibrary2018.msi
exe64_path=
exe_param=
materiallibrary2018cmill.log
Autodesk® Worksharing Monitor for Revit® 2018
Log file last modified: Fri Jun 2 16:21:58 2017
exe_path=x64\RWSM\RWSM.msi
exe64_path=
exe_param=
autodesk worksharing monitor for revit 2018 install.log
Autodesk® Model Review for Revit® 2018
Log file last modified: Fri Jun 2 16:21:53 2017
exe_path=
exe64_path=x64\RMR\RMR.msi
exe_param=
autodesk model review for revit 2018 install.log
Autodesk® eTransmit for Revit® 2018
Log file last modified: Fri Jun 2 16:21:42 2017
exe_path=x64\RET\RET.msi
exe64_path=
exe_param=
autodesk etransmit for revit 2018 install.log
Autodesk® Batch Print for Revit® 2018
Log file last modified: Fri Jun 2 16:21:30 2017
exe_path=
exe64_path=x64\RBPU\RBPU.msi
exe_param=
autodesk batch print for revit 2018 install.log
Autodesk® Personal Accelerator for Revit® 2018
Log file last modified: Fri Jun 2 16:21:17 2017
exe_path=x64\PACR\PACR.msi
exe64_path=
exe_param=
autodesk personal accelerator for revit 2018 install.log
Autodesk® Collaboration for Revit® 2018
Log file last modified: Fri Jun 2 16:21:09 2017
exe_path=
exe64_path=x64\RCAO\RCAO.msi
exe_param=
autodesk collaboration for revit 2018 install.log
Autodesk Workflows 2018
Log file last modified: Fri Jun 2 16:21:01 2017
exe_path=3rdParty\%platform%\Workflows\Workflow_%platform%.msi
exe64_path=
exe_param=
workflows 2018 install.log
Log file last modified: Fri Jun 2 16:20:55 2017
exe_path=x86\RVT\RVT.msi
exe64_path=x64\RVT\RVT.msi
exe_param=
autodesk revit 2018 install.log
Cloud License Manager
Log file last modified: Fri Jun 2 16:15:19 2017
exe_path=%platform%\CLM\CLIC_%platform%_Release.msi
exe64_path=
exe_param=
clm install.log
Autodesk® Revit® Content Libraries 2018
Log file last modified: Fri Jun 2 16:14:00 2017
exe_path=x86\RCL\RCL.msi
exe64_path=x64\RCL\RCL.msi
exe_param=
autodesk revit content libraries 2018 install.log
Machine Settings & Runtime Versions
Platform Information
Operating System = Windows-7-6.1.7601-SP1 64 bit
Processor = Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
Folder Shell Redirections - Per User
AppData = C:\Users\NStanisheva\AppData\Roaming
Local AppData = C:\Users\NStanisheva\AppData\Local
My Video = C:\Users\NStanisheva\Videos
{1B3EA5DC-B587-4786-B4EF-BD1DC332AEAE} = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Libraries
My Pictures = C:\Users\NStanisheva\Pictures
Desktop = C:\Users\NStanisheva\Desktop
History = C:\Users\NStanisheva\AppData\Local\Microsoft\Windows\History
NetHood = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Network Shortcuts
{56784854-C6CB-462B-8169-88E350ACB882} = C:\Users\NStanisheva\Contacts
Cookies = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Cookies
Favorites = C:\Users\NStanisheva\Favorites
SendTo = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\SendTo
Start Menu = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Start Menu
My Music = C:\Users\NStanisheva\Music
Programs = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Recent = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Recent
CD Burning = C:\Users\NStanisheva\AppData\Local\Microsoft\Windows\Burn\Burn
PrintHood = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
{7D1D3A04-DEBB-4115-95CF-2F29DA2920DA} = C:\Users\NStanisheva\Searches
{374DE290-123F-4565-9164-39C4925E467B} = C:\Users\NStanisheva\Downloads
{A520A1A4-1780-4FF6-BD18-167343C5AF16} = C:\Users\NStanisheva\AppData\LocalLow
Startup = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Administrative Tools = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Personal = C:\Users\NStanisheva\Documents
{BFB9D5E0-C6A9-404C-B2B2-AE6DB6AF4968} = C:\Users\NStanisheva\Links
Cache = C:\Users\NStanisheva\AppData\Local\Microsoft\Windows\Temporary Internet Files
Templates = C:\Users\NStanisheva\AppData\Roaming\Microsoft\Windows\Templates
{4C5C32FF-BB9D-43B0-B5B4-2D72E54EAAA4} = C:\Users\NStanisheva\Saved Games
Fonts = C:\Windows\Fonts
Folder Shell Redirections - Per Machine - 32 Bit
Common Desktop = C:\Users\Public\Desktop
Common Start Menu = C:\ProgramData\Microsoft\Windows\Start Menu
CommonVideo = C:\Users\Public\Videos
CommonPictures = C:\Users\Public\Pictures
Common Programs = C:\ProgramData\Microsoft\Windows\Start Menu\Programs
CommonMusic = C:\Users\Public\Music
Common Administrative Tools = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Common Startup = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Common Documents = C:\Users\Public\Documents
OEM Links = C:\ProgramData\OEM Links
Common Templates = C:\ProgramData\Microsoft\Windows\Templates
Common AppData = C:\ProgramData
Personal = C:\Users\WS-Earias\Documents\
Folder Shell Redirections - Per Machine - 64 Bit
.NET Versions installed
2.0.50727.5420 SP2 (32 bit)
3.0.30729.5420 SP2 (32 bit)
3.5.30729.5420 SP1 (32 bit)
4.6.01590 (no service pack) (32 bit)
2.0.50727.5420 SP2 (64 bit)
3.0.30729.5420 SP2 (64 bit)
3.5.30729.5420 SP1 (64 bit)
4.6.01590 (no service pack) (64 bit)
Visual C++ Runtimes installed
Microsoft Visual C++ 2005 Redistributable = 8.0.61001
Microsoft Visual C++ 2005 Redistributable = 8.0.56336
Microsoft Visual C++ 2005 Redistributable = 8.0.59193
Microsoft Visual C++ 2005 Redistributable (x64) = 8.0.56336
Microsoft Visual C++ 2005 Redistributable (x64) = 8.0.59192
Microsoft Visual C++ 2005 Redistributable (x64) = 8.0.61000
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 = 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 = 9.0.30729.4148
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 = 9.0.30729.6161
Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 = 9.0.21022
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 = 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 = 9.0.30729.4148
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 = 9.0.30729.6161
Microsoft Visual C++ 2008 x64 ATL Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x64 CRT Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x64 MFC Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x64 OpenMP Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x86 ATL Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x86 CRT Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x86 MFC Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2008 x86 OpenMP Runtime 9.0.30729 = 9.0.30729
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 = 10.0.40219
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 = 10.0.40219
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 = 11.0.60610.1
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 = 11.0.61030.0
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 = 11.0.60610.1
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 = 11.0.61030.0
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24212 = 14.0.24212.0
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24212 = 14.0.24212.0
Microsoft Visual C++ 2015 x64 Additional Runtime - 14.0.24212 = 14.0.24212
Microsoft Visual C++ 2015 x64 Minimum Runtime - 14.0.24212 = 14.0.24212
Microsoft Visual C++ 2015 x86 Additional Runtime - 14.0.24212 = 14.0.24212
Microsoft Visual C++ 2015 x86 Minimum Runtime - 14.0.24212 = 14.0.24212
Autodesk Components installed
Autodesk App Manager = 1.2.0 UninstallString = MsiExec.exe /X{C8125548-F2D5-4059-823F-1F3C5BBD9F19}
Autodesk AutoCAD 2015 - English = 20.0.51.0 UninstallString = C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup\Setup.exe /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
Autodesk AutoCAD 2015 - English SP2 = 20.0.210.0 UninstallString = Msiexec.exe /uninstall {1BE8FF4F-23D5-479C-8AF9-DA313E87D5AC} /package {5783F2D7-E001-0000-0102-0060B0CE6BBA} ADSK_SETUP_EXE=1 /qb
Autodesk AutoCAD 2015 VBA Enabler = 20.0.51.0 UninstallString = C:\Program Files\Autodesk\AutoCAD 2015 VBA Enabler\Setup\Setup.exe /P {FD0595A7-C560-4967-0133-ADCE7EE7644D} /M AcVbaInstaller /language en-US
Autodesk AutoCAD MEP 2015 - English = 7.7.49.0 UninstallString = C:\Program Files\Autodesk\AutoCAD 2015\MEP\Setup\en-us\Setup\Setup.exe /P {5783F2D7-E006-0000-0102-0060B0CE6BBA} /M MEP /language en-US
Autodesk AutoCAD Performance Feedback Tool Version 1.2.2 = 1.2.2.0 UninstallString = MsiExec.exe /X{85735431-6CD3-4B16-BEC8-95332034E53B}
Autodesk BIM 360 Glue AutoCAD 2015 Add-in 64 bit = 4.36.2452 UninstallString = MsiExec.exe /X{B0E4871A-09A2-49C3-9A9E-D6409B37FD3A}
Autodesk BIM 360 Navisworks Simulate 2015 Add-in 64 bit = 4.36.2452 UninstallString = MsiExec.exe /X{3DA87F6B-013D-4C10-AE7A-79A03F7776D9}
Autodesk BIM 360 Revit 2015 Add-in 64 bit = 4.36.2452 UninstallString = MsiExec.exe /X{0D801D98-061A-4A4C-92B5-D3EC03C35587}
Autodesk Collaboration for Revit 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Collaboration for Revit 2018\Setup\Setup.exe /P {AA384BE4-1800-0010-0000-97E7D7D00B17} /M RCAO /LANG en-US
Autodesk Collaboration for Revit 2018 = 18.0.0.420 UninstallString = MsiExec.exe /X{AA384BE4-1800-0010-0000-97E7D7D00B17}
Autodesk Content Service = 3.2.0.0 UninstallString = C:\Program Files (x86)\Autodesk\Content Service\Setup\Setup.exe /P {A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F} /M ContentService /LANG en-US
Autodesk Content Service Language Pack = 3.2.0.0 UninstallString = MsiExec.exe /X{A37CDB58-AAE8-0001-8C13-E0F7BACB0D5F}
Autodesk DWG TrueView 2014 = 19.1.18.0 UninstallString = C:\Program Files\Autodesk\DWG TrueView 2014\Setup\Setup.exe /P {5783F2D7-D028-0409-0100-0060B0CE6BBA} /M AOEM /language en-US
Autodesk Desktop App = 6.2.0.174 UninstallString = C:\Program Files (x86)\Autodesk\Autodesk Desktop App\removeAdAppMgr.exe
Autodesk Express Viewer = 3.1 UninstallString = C:\PROGRA~2\Autodesk\AUTODE~1\Setup.exe /remove
Autodesk Featured Apps = 1.2.0 UninstallString = MsiExec.exe /X{EDDEE94B-214D-4B07-9727-A3E46F3E379A}
Autodesk Installation Diagnostic Assistant = 1.5.0.0 UninstallString = MsiExec.exe /I{0C4B4EEC-C4E5-4E3E-B502-9BEAECBC3F01}
Autodesk License Service (x64) - 5.1.4 = 5.1.4.0 UninstallString = MsiExec.exe /X{28B17270-375A-4844-9D34-754A457E17BF}
Autodesk Material Library 2015 = 5.2.9.100 UninstallString = MsiExec.exe /I{427F733F-4D6C-45BC-9324-EB743104C321}
Autodesk Material Library 2018 = 16.11.1.0 UninstallString = MsiExec.exe /X{7847611E-92E9-4917-B395-71C91D523104}
Autodesk Material Library Base Resolution Image Library 2015 = 5.2.9.100 UninstallString = MsiExec.exe /I{ABE2F70B-8D94-44E9-AA04-F0DB35063D62}
Autodesk Material Library Base Resolution Image Library 2018 = 16.11.1.0 UninstallString = MsiExec.exe /X{FCDED119-A969-4E48-8A32-D21AD6B03253}
Autodesk Material Library Low Resolution Image Library 2015 = 5.2.9.100 UninstallString = MsiExec.exe /I{4FBC9635-AC56-4378-8FDE-C4D3ED072681}
Autodesk Material Library Low Resolution Image Library 2018 = 16.11.1.0 UninstallString = MsiExec.exe /X{1B0F011A-66B4-4865-98B7-0FE132841035}
Autodesk Material Library Medium Resolution Image Library 2015 = 5.2.9.100 UninstallString = MsiExec.exe /I{9F6466D9-6EFC-4A10-B931-C72D1A3F1763}
Autodesk Navisworks 2015 Exporters - 64 bit = 12.0.1109.12 UninstallString = C:\Program Files\Autodesk\Navisworks 2015 64 bit Exporter Plug-ins\setup\Uninstall.exe /P {C5254A2E-1B28-5E31-825A-6B672B374431} /M NW_EXPORTERS_64
Autodesk Navisworks 2015 Exporters - 64 bit = 12.0.1109.12 UninstallString = MsiExec.exe /I{C5254A2E-1B28-0409-825A-6B672B374431}
Autodesk Navisworks 2015 Exporters - 64 bit - English Language Pack = 12.0.1109.12 UninstallString = MsiExec.exe /X {C5254A2E-1B28-0409-825A-6B672B374431} /qb
Autodesk Navisworks 2015 Exporters - 64 bit - English Language Pack = 12.0.1109.12 UninstallString = MsiExec.exe /I{C5254A2E-1B28-0409-825A-6B672B374431}
Autodesk Navisworks Simulate 2015 = 12.3.1157.50 UninstallString = C:\Program Files\Autodesk\Navisworks Simulate 2015\setup\Uninstall.exe /P {9D7AF9A9-2E52-0000-B0D0-652C6A18F3B8} /M NW
Autodesk Navisworks Simulate 2015 = 12.3.1157.50 UninstallString = MsiExec.exe /I{9D6DFAD6-09E5-445E-A4B5-A388FEEBD90D}
Autodesk Navisworks Simulate 2015 - 2009 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{B0225F8F-483A-4ABF-AD72-63F5CA1F7A15}
Autodesk Navisworks Simulate 2015 - 2010 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{9EA4D5D3-56DB-4B4F-AF40-3950178CE251}
Autodesk Navisworks Simulate 2015 - 2011 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{8DA3934B-7873-46CC-A67C-54706D8E97BA}
Autodesk Navisworks Simulate 2015 - 2012 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{B94DD4C4-632E-4EA7-97C4-94C3002189A6}
Autodesk Navisworks Simulate 2015 - 2013 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{F2AB5586-5E2F-4971-BC10-5DB8C38B59B3}
Autodesk Navisworks Simulate 2015 - 2014 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{051FD4D2-A63E-4796-929B-FB3B14E4DEB3}
Autodesk Navisworks Simulate 2015 - 2015 DWG File Reader = 12.0.1109.12 UninstallString = MsiExec.exe /I{572D5A65-A177-426E-98FE-2221C2D612DC}
Autodesk Navisworks Simulate 2015 - English Language Pack = 12.0.1109.12 UninstallString = MsiExec.exe /X {9D7AF9A9-2E52-0409-B0D0-652C6A18F3B8} /qb
Autodesk Navisworks Simulate 2015 - English Language Pack = 12.0.1109.12 UninstallString = MsiExec.exe /I{9D7AF9A9-2E52-0409-B0D0-652C6A18F3B8}
Autodesk ReCap = 1.4.0.132 UninstallString = C:\Program Files\Autodesk\Autodesk ReCap\Setup\Setup.exe /P {31ABA3F2-0000-1033-0102-111D43815377} /M Autodesk_ReCap /LANG en-US
Autodesk ReCap = 1.4.0.132 UninstallString = MsiExec.exe /X{28B17270-375A-4844-9D34-754A457E17BF}
Autodesk Revit 2015 = 15.0.1170.0 UninstallString = C:\Program Files\Autodesk\Revit 2015\Setup\en-US\Setup\Setup.exe /P {7346B4A0-1500-0510-0000-705C0D862004} /M RVT2015 /LANG en-US
Autodesk Revit 2015 UR4 = 15.0.1103.0 UninstallString = Msiexec.exe /uninstall {9CA05B9A-1505-0510-0000-FFF7A680FE55} /package {7346B4A0-1500-0510-0000-705C0D862004} /qb FILESINUSETEXT=""
Autodesk Revit 2015 UR8 = 15.0.1170.0 UninstallString = Msiexec.exe /uninstall {9CA05B9A-1509-0510-0000-FFF7A680FE55} /package {7346B4A0-1500-0510-0000-705C0D862004} /qb FILESINUSETEXT="The following applications should be closed before continuing the install:"
Autodesk Revit 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Revit 2018\Setup\Setup.exe /P {7346B4A0-1800-0510-0000-705C0D862004} /M RVT /LANG en-US
Autodesk Revit Content Libraries 2015 = 15.0.117.0 UninstallString = C:\Program Files\Autodesk\Revit Content 2015 English\Setup\en-US\Setup\Setup.exe /P {941030D0-1500-0410-0000-818BB38A95FC} /M RCL2015 /LANG en-US
Autodesk Revit Content Libraries 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Revit Content 2018\Setup\Setup.exe /P {941030D0-1800-0410-0000-818BB38A95FC} /M RCL /LANG en-US
Autodesk Revit Interoperability for Navisworks Simulate 2015 = 15.0.107.0 UninstallString = MsiExec.exe /X{0BB716E0-1500-0910-0000-097DC2F354DF}
Autodesk Revit Model Review 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Revit Model Review 2018\Setup\Setup.exe /P {715812E8-1800-0010-0000-BBB894911B46} /M RMR /LANG en-US
Autodesk Revit Model Review 2018 = 18.0.0.420 UninstallString = MsiExec.exe /X{715812E8-1800-0010-0000-BBB894911B46}
Autodesk Workflows 2015 = 5.2.11.100 UninstallString = MsiExec.exe /X{A90DD6F8-60D2-4803-AFF6-796400E73E1B}
Autodesk Workflows 2018 = 16.11.1.0 UninstallString = MsiExec.exe /X{28B17270-375A-4844-9D34-754A457E17BF}
Batch Print for Autodesk Revit 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Batch Print for Revit 2018\Setup\Setup.exe /P {82AF00E4-1800-0010-0000-FCE0F87063F9} /M RBPU /LANG en-US
Batch Print for Autodesk Revit 2018 = 18.0.0.420 UninstallString = MsiExec.exe /X{82AF00E4-1800-0010-0000-FCE0F87063F9}
Space Naming Utility for Autodesk Revit MEP 2015 = 15.0.136.0 UninstallString = C:\Program Files\Autodesk\Space Naming Utility for Revit MEP 2015\Setup\Setup.exe /P {9DF3183F-1500-0010-0409-DD46CF717730} /M RSNU2015 /LANG en-US
Space Naming Utility for Autodesk Revit MEP 2015 = 15.0.136.0 UninstallString = MsiExec.exe /X{9DF3183F-1500-0010-0409-DD46CF717730}
Worksharing Monitor for Autodesk Revit 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\Setup\Setup.exe /P {5063E738-1800-0010-0000-7B7B9AB0B696} /M RWSM /LANG en-US
Worksharing Monitor for Autodesk Revit 2018 = 18.0.0.420 UninstallString = MsiExec.exe /X{5063E738-1800-0010-0000-7B7B9AB0B696}
eTransmit for Autodesk Revit 2018 = 18.0.0.420 UninstallString = C:\Program Files\Autodesk\eTransmit for Revit 2018\Setup\Setup.exe /P {4477F08B-1800-0010-0000-9A09D834DFF5} /M RET /LANG en-US
eTransmit for Autodesk Revit 2018 = 18.0.0.420 UninstallString = MsiExec.exe /X{4477F08B-1800-0010-0000-9A09D834DFF5}
Link to running processes on computer
Autodesk Building Design Suite Premium 2018 Setup_processes.txt
Free Disk Space:
Drive C = 318982828032 bytes free
Drive F = 133312565248 bytes free
Drive G = 133312565248 bytes free
Link to mapped & substituted drives on computer
Autodesk Building Design Suite Premium 2018 Setup_mappings.txt
Permissions Tests:
Directory Access: ProgramFiles
---Path: C:\Program Files
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: ProgramFiles(x86)
---Path: C:\Program Files (x86)
---Exists = True
---Read = True
---Write = True
---Applies To = x64
Directory Access: ProgramData
---Path: C:\ProgramData
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: AppData
---Path: C:\Users\NStanisheva\AppData\Roaming
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: LocalAppData
---Path: C:\Users\NStanisheva\AppData\Local
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: CommonFiles
---Path: C:\Program Files\Common Files
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: CommonFiles(x86)
---Path: C:\Program Files (x86)\Common Files
---Exists = True
---Read = True
---Write = True
---Applies To = x64
Directory Access: Temp
---Path: C:\Users\NSTANI~1\AppData\Local\Temp
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: TMP
---Exists = True
---Read = True
---Write = True
---Applies To = all
Registry Access: HKLM_Software
---Key: HKEY_LOCAL_MACHINE\Software
---Read = True
---Write = True
---Applies To: all
Registry Access: HKCU_Software
---Key: HKEY_CURRENT_USER\Software
---Read = True
---Write = True
---Applies To: all
