Installation & Licensing
autocad 2018 already installed
3 REPLIES 3
1746 Views, 3 Replies
I am trying to install cad 2018 on my computer, the first installation was unsuccesful. I have cleaned everything, all the folders, force to uninstall via command prompt (because I couldn't do a proper uninstall). When I try re-installing it says cad 2018 is already installed... but it's not.
I have deleted/unsintall everything. It feels like there is some kind of ghost files.
What can I do?
I tried this it didn't work :
https://forums.autodesk.com/t5/installation-licensing/autocad-already-installed/td-p/4499237
Thank you,
Noe
What can I do?
Thank you,
Noe
3 REPLIES 3
Mark.Lancaster
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
You will need to use Microsoft Fixit at this point.
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
Mark Lancaster
@Anonymous
Mark Lancaster
robBouch
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
Welcome to the community!
@Mark.Lancaster is correct. I would also suggest using the MS Fixit tool to uninstall.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hello @Anonymous
robBouch
robBouch
Autodesk Support
Autodesk Support
Hello @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hello @Anonymous
Administrator Productivity
