Installation & Licensing
AutoCAD 2017 with SSO for licensing
3 REPLIES 3
bmrnksi
617 Views, 3 Replies
Hi All -
Wondering if anyone has had success moving to the subscription licensing model with SSO, Azure AD in my case, and getting AutoCAD 2017 to connect properly?  I've patch to 2017.1.2 and applied the enterprise SSO patch and still no luck.
If I upgraded to AutoCAD 2018 or 2021 there is no problem.  Why don't I upgrade?  Because there's an application dependency with my users who are using an older version of Meridian content management software for AutoCAD that limits these users to AutoCAD 2017.
Anyone's thought would be appreciated.  I am going to try a fresh install, but for now that's where I'm at.
-Kelvin
Tags (2)
Labels (2)
3 REPLIES 3
pendean
in reply to: bmrnksi
Why don't you do as the pop-up suggests to find out more, then share it here if you need help
bmrnksi
in reply to: pendean
@pendean  -
Thanks for the suggestion.  Unfortunately, clicking to Enabled advanced diags did nothing.
I did however talk to my co-worker who knows the Azure SSO stuff better, and he's seeing my attempts to SSO via AutoCAD 2017:
Failure reason: Device authentication is required.
Interesting for the AutoCAD 2017 SSO attempts, it incorrectly identifies my laptop as running Windows 8, where as when I run a newer version of AutoCAD, it correctly shows my device as Windows 10.
We believe AutoCAD 2017 is not properly sending the device information in the SSO communication to Azure.
With newer versions of AutoCAD (tested 2018 and 2021) this works just fine.
Let me what you think about this assessment.
-Kelvin
pendean
I agree with your observations: looks like you folks will need to upgrade at some point, hope you can find an alternate to the old add-on you wish to continue using.
Administrator Productivity
