Hello Ms Emms,
Response, in order, to suggested use of 10 Tips:
1. System restore: takes me to an automatic point of Nov 14 just prior to re & re of Windows C++ programs. I have not done this yet.
2. AutoCAD 2017 is not showing in Windows Control Panel, so it must be uninstalled, yes?
3. In searching for AutoCAD program files I found none in:
Windows Settings > Windows Apps & Features nor in Control Panel > Programs & Features...
BTW I did see that i had some foreign language versions of sds Max installed, can I remove them since I use English only?
4. Windows 8 Uninstall: See attached screen shots to see some of 289 results for AutoCAD search on C Drive.
5. I have tried reinstall already, as i open after reinstall, I get the same error message 'Problem loading acadres.dll resource file.'
6. Tip 6, MS Office N/A to Autodesk downloads.
7. I will try IOBit if needed...
8. Applicable to Windows Modern Apps only.
9. Powershell? N/A in this case
10. N/A in this case.
Re your very last post suggesting my using 'Submitting & Viewing Support Requests' link, you are my latest effort in following this avenue 'Autodesk Knowledge Network > Account Management > Tech Support > Installation, Activation & Licensing.
I have been working for a week or more trying to get this reinstall/download issue resolved and really need to get it done so that I can work on assignments at home.
Can we expedite the installation with a schedule a screen share?
Tommy
