Edit: this problems happens in a standalone install.
I've seen this problem reported in the forums for previous versions of Autocad, but none of the proposed solution worked for me. I installed Autocad 2016 in a new computer without any previous Autocad install. After ~2 months, the program gets stuck in the splash screen showing the message "Checking License". Yes, there are many threads about this out there, but nothing worked for me.
Let me provide a little more technical detail about this. At some point during the program startup, it starts the "Flexnet Licensing Service" service, spawning a process named FNPLicensingService.exe, and this process hangs. If I kill such process, it seems that Autocad repeatedly starts if again. I also tried to start the service manually and it returns error 1053 (the service does not return the control to the Service Control Manager within 30 seconds). It seems this starts to happen after some time, not sure why. I've checked that FlexNet License Service folder contains files with last write time equal to the date I installed Autocad, which seems logical.
These are the things that I tried:
- Waiting for several hours for the "Checking License" screen to finish.
- Fully uninstalling and reinstalling Autocad
- Disabling antivirus and firewall
- Removing license files under %ProgamData%\Flexnet
- Removing %ProgramData%\Autodesk\AdLm, individual files or the whole folder.
- Installing from a fresh newly created administrator account.
- System restore to a restore point where everything worked.
- Restored %ProgramData%\Autodesk\AdLm and/or %ProgamData%\Flexnet to previous versions.
Things that I refuse to try because they are atrocities and potentially would hurt my computer:
- Downgrade Internet Explorer version (wtf)
- Formatting PC and start fresh (a coworker states that this happened to him and this is how he solved it)
My system also has Acrobat XI Pro (legal license), don't know if it may be related, and an old install of Autocad 2006, installed with Longbow Converter (the user requested so).
By the way, this happens on Windows 8.1 Pro 32 bits, joined to a domain. PC has Intel i3 processor (can provide more system info if needed/useful).
Please, I beg you, provide a solution for this. I've lost hours of work trying to fix this. Thank you very much.
