Autodesk Licensing Error 110 & cannot open Maya 2014
Hi there
Am a student and installed the trial version of maya 2014 2 months back. No problem there however I am now unable to install the student version. it says error code 110. Help!
Otto
Hello 86Sanjay and welcome to the Autodesk community!
It looks like you're getting Error 110 during activation. This error typically occurs when something in the licensing folder is corrupt.
The following instructions should help you resolve the problem:
Uninstall ALL autodesk software and then delete the folder containing the licensing components and then re-install. Here are the steps to do this:
  1. Uninstall Autodesk software
  2. Delete C:\ProgramData\Autodesk\Adlm and all contents
  3. Delete the ADSKFLEX files in C:\ProgramData\Flexlm
  4. Re-install autodesk software.
Did that work? If so, please accept this solution so that others can benefit from this information. If not, please reply with additional details so that other community members can assist.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Hello
Do you have a solution for Mac?
OS X 10.9.5
camilo.lemos
Hi @Anonymous and welcome to the Autodesk Community!
For Macs, please uninstall your current version of Maya and install this Service Pack.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
Hi @camilo.lemos! Worked perfect! Thank you for your prompt assistance!
camilo.lemos
@Anonymous You're most welcome!
Camilo Lemos
