Installation & Licensing
Autocad 2016 installation error
3 REPLIES 3
397 Views, 3 Replies
Hi everyone,
I had error when install AutoCAD 2016 32bits.
I cannot complete installation, it's fail installation at C++ 2008.
3 REPLIES 3
Darin.Green
@Anonymous
It's hard to determine the issue without your installation log found in the %temp% directory. Please provide the installation log file. Meanwhile, try the following:
  1. Download the software from Autodesk Virtual Agent
  2. Disable your antivirus application
  3. Disable UAC (User Account Control)
  4. Uninstall all versions of Visual C++ 2008 and higher (Let the Autodesk installer install it for you)
  5. Right-Click Setup.exe and choose Run as Administrator
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
Hi Darin Green,
Here is my installation log file. Help me please.
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:47:33 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp
2017/4/24:08:49:52 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp
2017/4/24:08:47:39 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:49:01 Administrator LVD-MUC0707SHA Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:49:01 Administrator LVD-MUC0707SHA Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:49:02 Administrator LVD-MUC0707SHA Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID69.tmp\Setup\AcSetup.dll
2017/4/24:08:49:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:49:52 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:50:10 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:50:46 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:50:47 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:50:48 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:50:48 Administrator LVD-MUC0707SHA Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:50:52 Administrator LVD-MUC0707SHA Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:50:52 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:51:12 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:51:13 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:51:52 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:52:43 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp
2017/4/24:08:52:53 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp
2017/4/24:08:52:45 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIC929.tmp\Setup\AcSetup.dll
2017/4/24:08:52:46 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:52:47 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:53:03 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:53:06 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:53:07 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:53:08 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:53:22 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:53:23 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:53:33 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:08:55:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp
2017/4/24:08:55:14 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp
2017/4/24:08:55:05 Administrator LVD-MUC0707SHA Launch
2017/4/24:08:55:06 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:08:55:06 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIEBE5.tmp\Setup\AcSetup.dll
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:08:55:07 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:08:55:23 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:08:55:30 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:08:55:31 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:08:55:43 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:08:55:44 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:08:59:02 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp
2017/4/24:09:01:30 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp
2017/4/24:09:01:24 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIAFEF.tmp\Setup\AcSetup.dll
2017/4/24:09:01:25 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:01:26 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:01:43 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:01:46 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:01:47 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:01:58 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:01:58 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:02:06 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:05:36 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp
2017/4/24:09:06:21 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp
2017/4/24:09:05:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:05:40 Administrator LVD-MUC0707SHA Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:05:40 Administrator LVD-MUC0707SHA Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:05:41 Administrator LVD-MUC0707SHA Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI91F4.tmp\Setup\AcSetup.dll
2017/4/24:09:06:20 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:06:21 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:06:43 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:06:43 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:06:44 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:06:49 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:06:50 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:06:51 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:06:51 Administrator LVD-MUC0707SHA Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:06:53 Administrator LVD-MUC0707SHA Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:06:53 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:07:01 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:07:02 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:07:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:08:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp
2017/4/24:09:08:14 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp
2017/4/24:09:08:05 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID1D1.tmp\Setup\AcSetup.dll
2017/4/24:09:08:07 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:08:08 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:08:19 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:08:20 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:08:20 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:08:23 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:08:24 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:08:24 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:08:25 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:08:25 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:08:32 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:08:33 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:09:46 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:10:47 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp
2017/4/24:09:10:56 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp
2017/4/24:09:10:49 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:10:50 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI51F8.tmp\Setup\AcSetup.dll
2017/4/24:09:10:51 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:10:52 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:11:06 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:11:31 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:11:32 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:11:33 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:11:45 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:11:45 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:12:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:13:58 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp
2017/4/24:09:14:08 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp
2017/4/24:09:14:00 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI3B2D.tmp\Setup\AcSetup.dll
2017/4/24:09:14:01 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:14:02 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:14:16 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:14:20 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:14:21 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:14:22 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:14:34 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:14:35 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:15:02 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:20:47 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp
2017/4/24:09:20:57 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp
2017/4/24:09:20:49 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI7956.tmp\Setup\AcSetup.dll
2017/4/24:09:20:50 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:20:51 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:21:05 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:21:15 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:21:16 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:21:25 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:21:25 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:23:49 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIF49D.tmp
2017/4/24:09:24:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:24:41 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:09:24:35 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIF49D.tmp
2017/4/24:09:24:49 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:25:58 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp
2017/4/24:09:26:10 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp
2017/4/24:09:26:01 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI389E.tmp\Setup\AcSetup.dll
2017/4/24:09:26:02 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:26:03 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:26:16 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:26:19 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:26:20 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:26:33 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:26:34 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:26:42 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:31:29 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp
2017/4/24:09:31:41 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp
2017/4/24:09:31:31 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIC9D.tmp\Setup\AcSetup.dll
2017/4/24:09:31:34 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:31:36 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:31:54 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:31:58 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:31:59 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:32:00 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:32:26 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:32:29 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:33:44 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:38:07 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp
2017/4/24:09:38:16 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp
2017/4/24:09:38:09 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI1EA7.tmp\Setup\AcSetup.dll
2017/4/24:09:38:10 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:38:11 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:38:26 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:38:36 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:38:37 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:38:38 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:38:51 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:38:52 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:39:45 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:09:52:37 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp
2017/4/24:09:52:46 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp
2017/4/24:09:52:38 Administrator LVD-MUC0707SHA Launch
2017/4/24:09:52:39 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI63E1.tmp\Setup\AcSetup.dll
2017/4/24:09:52:40 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:09:52:41 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:09:52:52 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:09:52:56 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:09:52:57 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:09:52:58 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:09:53:18 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:09:53:19 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:09:53:31 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:12:21:03 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp
2017/4/24:12:21:30 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp
2017/4/24:12:21:09 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:21:11 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:12:21:11 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:12:21:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI4829.tmp\Setup\AcSetup.dll
2017/4/24:12:21:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:12:21:14 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:12:21:39 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:12:21:42 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:12:21:43 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:12:21:44 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:12:22:06 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:12:22:09 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:12:33:59 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/4/24:12:35:00 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp
2017/4/24:12:35:10 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp
2017/4/24:12:35:01 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x86...
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID6B.tmp\Setup\AcSetup.dll
2017/4/24:12:35:03 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:12:35:04 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:12:35:59 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:12:36:01 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:12:36:02 Administrator LVD-MUC0707SHA Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/STARTMARK...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/VCREDIST2...
2017/4/24:12:36:03 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:12:36:12 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:12:36:13 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:01:00 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Launch
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:12:59:36 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:12:59:56 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:09 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:43 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:44 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:45 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:46 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:47 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:48 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:51 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:51 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:00:52 Administrator LVD-MUC0707SHA Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2017/4/24:13:01:16 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:01:16 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp
2017/4/24:13:01:36 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp
2017/4/24:13:01:21 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:01:22 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI93D9.tmp\Setup\AcSetup.dll
2017/4/24:13:01:22 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:01:31 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:01:38 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:01:57 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:03:53 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:04:02 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:04:02 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:04:24 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:13:04:26 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:04:36 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:13:17:52 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp
2017/4/24:13:18:08 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp
2017/4/24:13:17:56 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:17:57 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI4B46.tmp\Setup\AcSetup.dll
2017/4/24:13:17:57 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:18:06 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:18:11 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:18:23 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:19:00 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:19:44 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:19:44 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:20:02 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:13:20:04 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:24:20 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:13:42:28 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID369.tmp
2017/4/24:13:42:49 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AID369.tmp
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AID369.tmp\Setup\AcSetup.dll
2017/4/24:13:42:33 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:42:38 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:42:41 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:42:44 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:43:08 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:43:12 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:43:12 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:43:25 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:13:43:26 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:13:43:31 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:13:44:07 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI57A5.tmp
2017/4/24:13:44:26 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:13:44:11 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:13:44:11 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:13:44:11 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI57A5.tmp
2017/4/24:13:44:11 Administrator LVD-MUC0707SHA Launch
2017/4/24:13:44:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI57A5.tmp\Setup\AcSetup.dll
2017/4/24:13:44:12 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:13:44:16 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:13:44:18 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:13:44:21 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:13:44:43 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:13:44:47 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:13:44:47 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:13:45:03 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/4/24:13:45:04 Administrator LVD-MUC0707SHA PageOpen InstallCompleteDialog
2017/4/24:14:03:04 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA Launch
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA CommandLine
2017/4/24:14:07:12 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7543.tmp
2017/4/24:14:07:36 Administrator LVD-MUC0707SHA === Setup ended ===
2017/4/24:14:07:18 Administrator LVD-MUC0707SHA === Setup started on LVD-MUC0707SHA by Administrator ===
2017/4/24:14:07:18 Administrator LVD-MUC0707SHA Path_Length: 154
2017/4/24:14:07:18 Administrator LVD-MUC0707SHA Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI7543.tmp
2017/4/24:14:07:18 Administrator LVD-MUC0707SHA Launch
2017/4/24:14:07:19 Administrator LVD-MUC0707SHA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI7543.tmp\Setup\AcSetup.dll
2017/4/24:14:07:19 Administrator LVD-MUC0707SHA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:14:07:25 Administrator LVD-MUC0707SHA PageOpen LaunchDialog
2017/4/24:14:07:28 Administrator LVD-MUC0707SHA PageOpen LicenseDialog
2017/4/24:14:07:35 Administrator LVD-MUC0707SHA PageOpen ProductInfoDialog
2017/4/24:14:08:04 Administrator LVD-MUC0707SHA PageOpen ProductSelectionDialog2
2017/4/24:14:08:07 Administrator LVD-MUC0707SHA PageOpen FullProgressDialog
2017/4/24:14:08:08 Administrator LVD-MUC0707SHA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2016_English_Win_32bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:14:08:19 Administrator LVD-MUC0707SHA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Thank you,
Mark.Lancaster
@Anonymous
Remove all instances of C++ from your Windows Control Panel/Program and Features/Add&Remove programs.   Then run the installer again and it will put those required C++ on.
Mark Lancaster
Administrator Productivity
