i tried everything to download it but it keeps sending me this message after the installation begins till it comes to 6 out of 9 this message always appear
Solved by natasha.l. Go to Solution.
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Hi @Anonymous,
Welcome to the community
I would also recommend using Virtual Agent as @Darin.Green mentioned. If that doesn't help, you could clear your TEMP folder before attempting to install it again. Here is a post from yesterday where the member had a similar problem with both AutoCAD 2016 & 2017 running on Windows 10. I mention a couple of possible step-by-step solutions which might be worth looking at if Virtual Agent alone doesn't do the trick for you.
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
Hello @Anonymous,
I am sorry to hear you are having problem install your AutoCAD 2016 software.
You can download your software via the Autodesk Virtual Agent.
Please proceed as follows:
W7: http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
W10: http://winaero.com/blog/how-to-turn-off-and-disable-uac-in-windows-10/
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
