Installation & Licensing
AutoCAD 2015 0xc0000142 Error occured.
111 REPLIES 111
Message 1 of 112
119501 Views, 111 Replies
Hello.
I installed new autocad 2015 (subscription upgrade).
But I could not start program cause 0xc000142 error.
I tested acrobat unstall method and disable vaccine before autocad install, but it is not operate.
If someone have solution?
I use Windows 7 64bit.
I have 2 licenses and other pc is no problem to start autocad 2015 but other ones have a start problem.
111 REPLIES 111
Message 101 of 112
in reply to: nguyenducanh.ktqs
Thks for your attempt at helping but I have no interest in going through
that procedure. If Autodesk cannot provide a product that installs properly
I will remain with acad2016. All I have to say is that Autodesk needs to
work out what are the issue. I have jobs to complete and have no time for
this nonsense. I have no issues with any other software except AutoCad.
Every time I try to upgrade, it's the same story. Autodesk needs to be held
accountable for this high price software.
Don L Rocheleau MAATO
RockWater Technical
705 698 7552
Message 102 of 112
Mustaqueem_Arif
 Hello,Mazel
Can you try this And Reinstall Software
http://upandready.typepad.com/up_and_ready/2014/03/autocad-2015-application-error-0xc0000142-autorun...
Thanks and Regards,
Mustaqueem Arif.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always wellcome.
Message 103 of 112
My problem was with the switchable Graphics - Autocad 2015 was using the discrete card with the high performance settings inside the AMD Catalyst CC, but it didn't work and gave the 0xc0000142 Error. I used the Catalyst Control center and forced autodesk to use the Intel Graphics card, then Autocad 2015 worked fine.
Message 104 of 112
nguyenducanh.ktqs
sorry everyone. I solved the problem. thanks you everyone
Message 105 of 112
Alfred.NESWADBA
Please find these threads with suggestions and solutions for that error >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 106 of 112
in reply to: TravisNave
Stick and stol may brake my bones.
I tried this, didn't work unfortunately.
Did uninstalling and re-installing it work for anyone else?
Message 107 of 112
Mark.Lancaster
@Anonymous
May I ask why you repeatedly post the same response every few days?
Mark Lancaster
Message 108 of 112
Nice and informative thanks for sharing it.
Message 109 of 112
Thanks for sharing it.
Message 110 of 112
Message 111 of 112
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Please explain what?
Mark Lancaster
Message 112 of 112
Mustaqueem_Arif
Hi
Welcome to the Autodesk User's Community..Share your information and errors and problems that come with Autodesk Software.
Thanks and Regards,
Mustaqueem Arif.
Administrator Productivity
