After downloading the 30-day trial of AutoCAD Architecture 2014, I am prompted to give a serial number and product key. I don't have one since it is a trial. What am I supposed to do??
Solved by philip.s. Go to Solution.
Hi tylerb94.tb,
When you reach the activation page, you should be seeing 2 options, "Enter your Serial Number" and "Activate using a 30 day Trial Period", choose the latter.
Afterwhich, the software will then be installed and you should be able to use and try it out.
then no you can't install 2014 autocad architecture as a trial
DarrenP
Confirming that once you have activated a version of the software and/or uninstalled the software during a trial period, upon reinstalling it, you will no longer be able to utilize that particular version as a trial.
