Installation & Licensing
349 Views, 1 Reply
Authentication
We have a network license for Autodesk Plant3D and I am trying to install a stand alone on my laptop. The install program gives that option and it appears everything installs but when I try and run it the splash screen shows and it says loading everything then it says getting license and never goes past that. I never get a chance to authenticate it. Any help
1 REPLY 1
aaronhai
Hi c4thman,
Welcome to Autodesk Discussion Group.
This issue could be cause by corruption of the lciensing info. If you only have single product installed in your machine, please delete the adsk*.data file to force re-activation. Please note that this will force re-activation for all Autodesk product currently installed in your machine so if you have critical work that needs other products to run, please consider if you wish to proceed.
To delete the licensing info, backup and remove these files:
On Vista, Windows 7 or 8
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.?backup
On Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
Thank you.
Aaron Hai
Administrator Productivity
