I tried installing Autocad 2017 free trial version on my laptop and below is the failed installation log:
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 === Setup started on DEEPTHOUGHT2 by tarek ===
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 Path_Length: 162
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 Launch
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 CommandLine /akamai /sid SESSION_ID /trialMode /url "http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Setu..."
2017/3/14:11:46:33 tarek DEEPTHOUGHT2 Current Directory C:\Users\CHCGH_~1\AppData\Local\Temp\_AID356.tmp
2017/3/14:11:47:01 tarek DEEPTHOUGHT2 === Setup ended ===
2017/3/14:11:46:35 tarek DEEPTHOUGHT2 === Setup started on DEEPTHOUGHT2 by tarek ===
2017/3/14:11:46:35 tarek DEEPTHOUGHT2 Path_Length: 162
2017/3/14:11:46:35 tarek DEEPTHOUGHT2 Current Directory C:\Users\CHCGH_~1\AppData\Local\Temp\_AID356.tmp
2017/3/14:11:46:35 tarek DEEPTHOUGHT2 Launch
2017/3/14:11:46:35 tarek DEEPTHOUGHT2 Download Play SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2017/3/14:11:46:36 tarek DEEPTHOUGHT2 Download Complete SETUPMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARKER...
2017/3/14:11:46:36 tarek DEEPTHOUGHT2 Download Play SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2017/3/14:11:47:00 tarek DEEPTHOUGHT2 Download Complete SETUP_CONFIG http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64.t...
2017/3/14:11:47:00 tarek DEEPTHOUGHT2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\CHCGH_~1\AppData\Local\Temp\_AID356.tmp\Setup\AcSetup.dll
2017/3/14:11:47:00 tarek DEEPTHOUGHT2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/14:11:47:02 tarek DEEPTHOUGHT2 PageOpen LaunchDialog
2017/3/14:11:47:45 tarek DEEPTHOUGHT2 PageOpen LicenseDialog
2017/3/14:11:47:49 tarek DEEPTHOUGHT2 PageOpen ProductInfoDialog
2017/3/14:11:47:49 tarek DEEPTHOUGHT2 PageOpen ProductSelectionDialog2
2017/3/14:11:47:58 tarek DEEPTHOUGHT2 PageOpen FullProgressDialog
2017/3/14:11:47:59 tarek DEEPTHOUGHT2 Download Play STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2017/3/14:11:47:59 tarek DEEPTHOUGHT2 Download Complete STARTMARKER http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARKER...
2017/3/14:11:47:59 tarek DEEPTHOUGHT2 Download Play UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2017/3/14:11:48:01 tarek DEEPTHOUGHT2 Download Complete UCRT http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86.ta...
2017/3/14:11:48:01 tarek DEEPTHOUGHT2 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/14:11:48:01 tarek DEEPTHOUGHT2 Install Universal C Runtime (KB3118401) Succeeded
2017/3/14:11:48:01 tarek DEEPTHOUGHT2 Download Play VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2017/3/14:11:48:04 tarek DEEPTHOUGHT2 Download Complete VCREDIST2015X86 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2017/3/14:11:48:04 tarek DEEPTHOUGHT2 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\CHCGH_~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/14:11:48:05 tarek DEEPTHOUGHT2 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/14:11:48:05 tarek DEEPTHOUGHT2 Download Play VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2017/3/14:11:48:08 tarek DEEPTHOUGHT2 Download Complete VCREDIST2015X64 http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST201...
2017/3/14:11:48:08 tarek DEEPTHOUGHT2 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\CHCGH_~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/14:11:48:09 tarek DEEPTHOUGHT2 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/14:11:48:09 tarek DEEPTHOUGHT2 Download Play DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2017/3/14:11:48:12 tarek DEEPTHOUGHT2 Download Complete DIRECTX http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.tar...
2017/3/14:11:48:12 tarek DEEPTHOUGHT2 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/14:11:48:18 tarek DEEPTHOUGHT2 Install DirectX Runtime Succeeded
2017/3/14:11:48:18 tarek DEEPTHOUGHT2 Download Play CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2017/3/14:11:49:06 tarek DEEPTHOUGHT2 Download Aborted CM http://trial2.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lzma...
2017/3/14:11:49:06 tarek DEEPTHOUGHT2 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/14:11:49:06 tarek DEEPTHOUGHT2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/14:11:49:06 tarek DEEPTHOUGHT2 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/14:11:49:06 tarek DEEPTHOUGHT2 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Any help would be greatly appreciated!!
Hi and Welcome to AutoDesk Forum,
VISUAL AGENT is your place to download your need.try to start from there.
Good Luck..
