Installation & Licensing
Architecture 2024 never finishes installation with odis installer 1.40.0.24
0 REPLIES 0
Message 1 of 1
henkstubbe
194 Views, 0 Replies
I'm working on deployments, and with the current version of the odis installer Arch 2024 hangs on finalising the installation. This can be found in the logfiles:
2023-06-08T17:28:39.987 [DDA: 3252, single] [Installer DEBUG] [ Autodesk::DDA::PkgHandler::PkgHandlerImpl::InstallCompleteEventHandler ]   installation is completed
2023-06-08T17:28:39.988 [DDA: 3252, single] [Installer DEBUG] [ Autodesk::DDA::EventBus::Run ]   waiting event ackInstallationCompleteFromPkgHandler for target OperationHandler is captured
2023-06-08T17:28:39.988 [DDA: 3252, single] [Installer DEBUG] [ Autodesk::DDA::EventBus::Until ]   event handler for target OperationHandler is resumed because it has received all of the events: ackInstallationCompleteFromPkgHandler; . last received event: ackInstallationCompleteFromPkgHandler
2023-06-08T17:28:40.281 [DDA: 3252, single] [Installer DEBUG] [ Autodesk::DDA::UIHandler::UIHandlerImpl::PostFinishInstallEventHandler ]   Sending UI Post Finish Install
2023-06-08T17:28:40.282 [DDA: 3252, single] [Installer DEBUG] [ Autodesk::DDA::BaseHandler::Send ]   Sending message:  {"command":"POST_INSTALL_COMPLETE","request":{"eventSource":11,"eventTarget":1,"restartRequired":false},"source":"DDA_CORE","target":"DDA_UI","version":"DDA_V1"}
2023-06-08T17:29:00.914 [DDA: 3252, single] [Installer INFO] [ Autodesk::DDA::BaseHandler::{ctor}::<lambda_20a742db0dddb05b9a2b39e951593bef>::operator () ]   [IPC] UI ChannelWin::Listen: WaitForSingleObject timeout. error_code: 997, pipe_name: \\.\pipe\adsk_dda_sdk
2023-06-08T17:29:31.051 [DDA: 3252, single] [Installer INFO] [ Autodesk::DDA::BaseHandler::{ctor}::<lambda_20a742db0dddb05b9a2b39e951593bef>::operator () ]   [IPC] UI ChannelWin::Listen: WaitForSingleObject timeout. error_code: 997, pipe_name: \\.\pipe\adsk_dda_sdk
2023-06-08T17:30:01.187 [DDA: 3252, single] [Installer INFO] [ Autodesk::DDA::BaseHandler::{ctor}::<lambda_20a742db0dddb05b9a2b39e951593bef>::operator () ]   [IPC] UI ChannelWin::Listen: WaitForSingleObject timeout. error_code: 997, pipe_name: \\.\pipe\adsk_dda_sdk
2023-06-08T17:30:31.334 [DDA: 3252, single] [Installer INFO] [ Autodesk::DDA::BaseHandler::{ctor}::<lambda_20a742db0dddb05b9a2b39e951593bef>::operator () ]   [IPC] UI ChannelWin::Listen: WaitForSingleObject timeout. error_code: 997, pipe_name: \\.\pipe\adsk_dda_sdk
2023-06-08T17:31:01.450 [DDA: 3252, single] [Installer INFO] [ Autodesk::DDA::BaseHandler::{ctor}::<lambda_20a742db0dddb05b9a2b39e951593bef>::operator () ]   [IPC] UI ChannelWin::Listen: WaitForSingleObject timeout. error_code: 997, pipe_name: \\.\pipe\adsk_dda_sdk
This timeout is then being repeated ad infinitum.
After removal of the odis installer, and installing version 1.39.0.216 it works without issue.
"without issue", yeah it's still autodesk.. so not much good there of course.
Ever heard of testing your garbage?
0 REPLIES 0
Administrator Productivity
