Ken,
Set your log file verbosity to 9. Next, try to start ADT3. Once it fails,
open the log file, scroll down to the time of the failed attempt and look
for the user name and system hostname from where the start attempt was made.
If you do not see any hits from the system during that time frame, you are
not getting to the server at all, this indicates that either ACADSERVER
needs to be set or has been set incorrectly or you are having name
resolution problems. If you see hits, there is likely an error message
pointing to the problem.
If you still can not find anything, contact your dealed and ask them to call
product support for you.
jerry
"Ken Rappold" wrote in message
news:03FE9E1D65F5F6C207B782CCB2C0C0EA@in.WebX.SaUCah8kaAW...
> There isn't any recording of a failed attempt in the adlm.log file. The
> only mention of the ADT3 key/lic file within the adlm.log is:
> "01-Jan-23 11:01:50: Loaded key C:\Program Files\AdLM\Key\166.lic 1 tokens
> [MINIKEY]."
> It appears I failed to mention the ADT2i key/lic file works fine. Adlm.log
> file entries as follows:
> "01-Jan-23 11:01:50: Loaded key C:\Program Files\AdLM\Key\161.lic 1 tokens
> [MINIKEY]."
> and after successful launch of ADT2i:
> "01-Jan-23 11:22:47: user@computer [1], 161: SLID-1 1 issued, 1 in use."
> 01-Jan-23 11:23:02: user@computer [1], 161: SLID-1 1 returned, 0 in use
> (used: 0:00:00:15).
> "jerry milana" wrote in message
> news:C07D503BDA8F5EDCDD865F69FC71D317@in.WebX.SaUCah8kaAW...
> > Hi All,
> > Anyone having this problem, please contact your dealer and ask them to
> > contact Autodesk Product Support on your behalf. Tell the dealer to ask
> for
> > the network support group. One of the people from my team will either
> speak
> > to the dealer then or call them back and work to resolve this issue for
> you.
> > Your dealer should have the following information when they contact us:
> > ADT3 Serial Number and the name the product is registered to.
> > Number of ADT3 seats
> > A copy of your adlm.log file indicating a failed attempt to start ADT3.
> > jerry milana,
> > "jason martin" wrote in message
> > news:EDD6B4AB9B35A4AC8067DDD724E75B84@in.WebX.SaUCah8kaAW...
> > > I called the number (thanks by the way) and the guy didn't have any
idea
> > what I was
> > > talking about (imagine?). He did direct me to support.autodesk.com
and
> > said that I should
> > > download and install the service pack there. I download and applied
the
> > service pack (sp1
> > > for adt3).
> > > no joy. Doesn't help. Doesn't change anything (I'm sure that it
changes
> > some things but I
> > > can't get adt to launch so how would I know).
> > > back to the phones I guess...
> > > jason martin
> > > frankfurt-short-bruza
