There are 37 PC. I can get a program of AutoCAD,3D,and so on.
But I cannot do setup second PC, even 36PC.
Please teach me how to install the plural PC.
@Anonymous
Welcome to the community..
What 3D application are you talking about?
When you requested your educational license did you request the network version of the application?
What you need to do is to create a deployment and then deploy that all 37 machines. Make sure to download your software using the Autodesk Virtual Agent method or per these steps:
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Select the option to create a deployment and the options you need.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
