A software problem has caused Autodesk CFD to close unexpectedly
Message 1 of 11
It seems like I can't get CFD2019 to open a model.
I downloaded CFD 2019 (Browser Download), it installed fine.  The app launches fine, but when I tried to open one the tutorials (electronics model), CFD 2019 closes unexpectedly.  See attached file
I have:
-Dell Precision M6600 - 64 bit
-16 GB of RAM
-Running Win 7
-Graphics. NVIDIA Quadro 3000M
Any help is greatly appreciated.
Thanks.
Replies (10)
Message 2 of 11
benoit.neu-faber
Hi Viny,
Do you have the files of the tutorial models on a local drive ?
If the files are located on a network drive this can create issues.
Benoit
Message 3 of 11
No.  All the files are on the local hard drive.
Message 4 of 11
benoit.neu-faber
Can you check the product information,
Do you have installed the latest version : 19.2 ?
Message 5 of 11
benoit.neu-faber
You can download it : https://manage.autodesk.com
Message 6 of 11
I got 19.2, I just downloaded  it yesterday.
Message 7 of 11
KakaSungura
I experienced something like this a while back.
Did you open the tutorial model from within Inventor? Also, do you have other Addins in Inventor, other than the ones that come pre-installed?
Nikishika mouse wanajua ni mazishi!
Message 8 of 11
No, I did not use Inventor, I am using Autodesk CFD as stand alone. Then import the geometry.
Thanks.
Message 9 of 11
Anybody came across this issue, I am still searching for a fix, so far no luck.....Thanks.
Message 10 of 11
I just had the same issue with Autodesk CFD yesterday.  I looked for answers on this forum but no luck.  I tried the following that fixed the issue.
Go to your users folder C:\Users\UserNameFolder\AppData\Local and delete folders related to Autodesk and Temp folders do the same from Roaming directory.
I was able to get Autodesk CFD 2018.2 to launch again.
Hope this approach will work with your Autodesk CFD as well
Take care,
S.
Message 11 of 11
Thanks for your comment. But Could you please be more specific? delete what? exactly what should be deleted/removed? thanks.
