Installation & Licensing
Welcome to Autodeskโ€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
3dsmax 2017 mentalray.dlz error 127 on Windows 10
1 REPLY 1
631 Views, 1 Reply
Hi, I tried the solutions posted about this problem and they didn't worked (delete the folder of 3ds max 2017 on appdata/etc...). Any other suggestions? Is this a windows 10 problem? I tried reinstalling all the visual studio packages, no luck ๐Ÿ˜ž
1 REPLY 1
Otto
Otto
Hello kthalas and welcome to the Autodesk community!
It looks like you are seeing Error 127. The following article(s) should help you resolve the problem:
How to reset AutoCAD to defaults
Alternatively, please make sure you have the latest service pack installed before attempting to install the software.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk productsโ€”any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Administrator Productivity
