I have a fresh upto date version of windows 10 ( its a clean version i've just spent the last couple of days rebuilding everything )
I installed 3dsmax 2017 and got it up and running
At some point when I tried installing updates everything got corrupted. Now I can't go back and I can't go forward.
I have to use 2017 because the university I work for won't upgrade to 2018
Other than just deleting files whats the best way to uninstall max2017 ????
Add remove programs hangs or fails
Solved by natasha.l. Go to Solution.
I have 3dsmax 2018 installed as well and thats all working fine . I really really don't want to mess that installation up
I'm going to try killing max 2017 files by hand then reinstalling.
so far I've found
C:\Program Files\Autodesk
C:\Users\...\AppData\Local\Autodesk\3dsMax
C:\ProgramData\Autodesk\3DSMAX\2017
C:\ProgramData\Autodesk\3dsMax 2017
C:\Users\Ken\AppData\Roaming\Autodesk\3DSMAX\2017
theres also
C:\Users\...\Documents\3dsMax which I'm not sure what to do with
Any folders I've missed? Is there a way of cleaning the registry ?
If you remove 3DS MaX 2017 and leave the 2018 version, well you can't install a legacy version of a product when a newer version is there.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I'm sorry that's not true.
I Installed max2018
then I installed 2017
I used the offline installers
max 2018 and 2017 were working fine until i tried to update 2017
2018 is still fine
now 2017 is very broken and I need to rebuild it but I'm reluctant to poke around the registry without pro help
Ok So I removed all the files from the folders above.
I didn't mess with the registry.
max 2017 was still listed in the win 10 Program list . But I tried giving the main 3ds max 2017 Installer a shot ... and it worked
so .... next I have to figure out how to get it properly patched.
It doesn't help the the 'about 3ds max' dialog is cryptic.
With a fresh install of max 2017 the product version reads 19.0 commercial
on my win 7 laptop the patch version of 2017 simply reads 19. 0 update commercial ( so which of the many updates is that ? )
Hello @kenzor,
Welcome back!
Please conduct the following to conduct a complete uninstall of your product/s:
Keep us posted on this issue.
Remember to please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thanks Natasha, I wish I'd found those links you sent before I tried to rebuild things myself.
I'm mostly up and running now. Hopefully all this weirdness won't cause future problems.
I'm glad I didn't delete the license files it meant everything re-authorised cleanly.
The Microsoft fix it tool failed. BUT There is and option to fix stuff using a program ID . It would be great if we new where to find the windows software ID for max in case this happens again.
cheers
- ken
Hello @kenzor,
No problem, glad you resolved it. Thank you for coming back to the forum to let us know.
I have included down below a search conducted on the system for the product code, you can do this for any application. You have the option to enter a product code instead of selecting the product from the drop-down with the MsfixitTool. You would select the "Not Listed" and enter the Product Code.
Natasha
Helpful Links:
Interesting. How did you do the search for the product code? when I right click on the 3dsmax.exe I don't see the same details
