I have just reset my laptop, and not sure of which windows version I'm working on right now. I installed both autocad 2019 and 3ds max 2019. Autocad works fine but 3ds max won't launch. I tried to reinstall 3ds max but nothing changed.
Solved by natasha.l. Go to Solution.
@Anonymous
Welcome to the Autodesk User's Community..
Are you see the 3DS Max Splash Screen? Have you checked Windows Task Manager and made sure there's no mutiple 3DS Max processes running? Any error message? Does your graphics card meed the requirements?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous,
Before downloading & installing did you prepare the system fully? Are you sure you had a complete download double check the files loaded & the extraction?
You can try starting fresh being sure you do not have any interference on the operating system or the network.
You can have your Task Manager running during the download & install to be sure something on the operating system is not causing the issue.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
