Installation & Licensing
441 Views, 3 Replies
3DS Max trial issues
I have downloaded 3ds Max trial, used it for one day, after that it won´t load the starting screen properly.
Error would pop up, that there was problem with the java script on the loading screen page, so I can not see any buttons, except "enter serial number" button, that is not working anyway. If I click on any button on error popup, which is yes or no, it would shut down everything.
Any suggestions?
Thanks in advance.
Error java script: http://ipm.autodesk.com/ipm/common/scripts/2016/baseline-treatment.js
3 REPLIES 3
Otto
Hello kamilaclar and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
in reply to: Otto
I have uninstalled and reinstalled whole 3ds max installation. But it didn´t resolved my problem.
I am using win 10 64 bit version. I could used it for one whole day, did two restarts that day and it worked perfectly. After that I keep getting error message, that the java script couldn´t load. Nothing has changed on my computer between those two days.
Thanks for any ideas.:)
For those who will eventually come to the same problem: there is one solution, since the script is on autodesk webpage, you can disconnect from the internet and start the trial, after that you can connect back.
Once again, I am talking about this script: http://ipm.autodesk.com/ipm/common/scripts/2016/baseline-treatment.js
Thanks.:)
Administrator Productivity
