Announcements
3ds Max 2016 application stop when startup
Installed Infor
1. win7 -64 bit ;
2.3ds Max2016 Design64bit
3.V-ray.3.4 for 3dsmax2016;
First step:
1.startup the 3ds Max ---- > tested the system --- the 3ds Max working right ;
2. use the Vray rendering function -- OK ;
second  Step:
1. runging as a rendering server ( backburner) , connect to the manager is OK;
2. server can accept Job and runging the render task ( can finish few task )
3. the windows show the error "3ds Max application stop work "
4. I try to startup the 3ds Max manual , it can't launch anymore , even i reinstall the 3ds Max, it still not work.
Please kindly help me
supplementary Information:
1.Follow my 3ds max's error ,  if i change to startup 3dsmax in different Language ,
the 3ds max can startup and work, But it's not working stable ; Maybe can finished few render tasks with backburner server.  the some error will happen ;
 after that , i need to close the backburner server again , and startup the 3ds max in another language i don't use before ; and it will startup normally ; and then i will startup the backburner server , this machine still can get the Job from the Manager and make the render task ;
Later the 3ds max error again . this will circulatory until all eight Language used , this machine is dead now , Only rebuilt the OS and software ...
 @Alfred.DeFlaminis
Could you give me help on this issue ,  thanks a lot
tony.su
Autodesk Support
Autodesk Support
Could you try to reset 3ds max after you can't launch 3ds max?
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/Resettin...
I guess something was broken in your user setting. And I'm not sure what's it is.
Tony Su
Product Support
