1619 revit install error
Message 1 of 19
Hi
Ive been unable to install revit 2017 education version due to what appears to be a 1619 error among microsoft visual c++ as seen in the setup log. Ive looked at other posts of the same issue and have tried several methods of solving the problem, such as uninstalling all instances of microsoft visual c++, downloading from virtual agent, turning off anti virus and fire walls, and emptying %TEMP% file. All these methods have failed in the same way.
i have attached my set up log file and an image of failed installation.
thanks
Replies (18)
Message 2 of 19
Otto
Hello jackbradshaw and welcome to the Autodesk community!
It looks like you are seeing Error 1619 while trying to install a program. The following article(s) should help you resolve the problem:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Autodesk program installation fails
BIM 360 Add-in install error: "A newer version of this software is already installed"
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 19
Mark.Lancaster
@Anonymous
Start >>here<<, follow the advice and then run the setup.exe from the extracted files that came from the Autodesk Virtual Agent.  Good luck and report back on your progress.
Mark Lancaster
Message 4 of 19
Hi Mark
Followed the link you sent me and added temp folder in c drive to environment variables but it did not work
Message 5 of 19
Mark.Lancaster
@Anonymous
At this point..  Go into Windows Control Panel/Add&Remove programs..  Remove all instances of C++ (all versions and X86/64B).  Then use the Microsoft Fixit (link in my signature - but return to the posting to see my signature/link) and make sure all C++ stuff is removed from your system.  Then try again.  Also with Microsoft Fixit, you have to run it for each application that needs to be removed.
Mark Lancaster
Message 6 of 19
I uninstalled all instances of microsoft visual c++ and ran fix it. i couldnt see any instances of microsoft visual c++ in the uninstall section. tried installing revit again but had same problem.
i should also mention that i have installed revit 2017 before with no problem, however i had to reset my pc recently requiring a reinstall and during this reinstall my computer forceably restarted.
Message 7 of 19
Mark.Lancaster
@Anonymous
Can you provide your latest installation log file.
Mark Lancaster
Message 8 of 19
log file attached
Message 9 of 19
Mark.Lancaster
@Anonymous
Its still failing in the same spot..  At this point you will have to modify the installation ini file.  In the extracted folder of the download parts from the Autodesk Virtual Agent..  You will find a file called setup.ini.  Open it with notepad and locate the following section
The yellow highlighted title in the image...  Rename it so it will not find that section..  Save the ini file.  Try installation again.  If it fails provide log file again..  Sorry for all of these steps.
Mark Lancaster
Message 10 of 19
When i did this and tried to install i got a pop up saying VCREDIST2005SP1ATLX64 could not be found, and had to force quit installer
Message 11 of 19
Mark.Lancaster
@Anonymous
My bad.. Smiley Sad I shouldn't response to posting when its late and heading off to bed.  Smiley Very Happy
Reset the header back to the normal name and instead set the exe64_path=blank/nothing..  Meaning remove the highlighted portion, save, and try again.
Mark Lancaster
Message 12 of 19
install failed again, log attached
Message 13 of 19
Mark.Lancaster
@Anonymous
Its hanging on the same spot but with a different error message that I've never seen.  Instead of leaving that exe path = to a blank/nothing.  Can you delete the entire (exe path=) statement and try again.  Hope it works this time.
Mark Lancaster
Message 14 of 19
failed again
Message 15 of 19
Mark.Lancaster
May I ask what the C:\revit 4 directory is?
Mark Lancaster
Message 16 of 19
this is where i extracted to from my download
Message 17 of 19
Mark.Lancaster
Ok..  I've never see the error results of 5 so I will tag @Darin.Green and @TravisNave for the input.
Mark Lancaster
Message 18 of 19
Darin.Green
@Mark.Lancaster - Thanks for tagging me on this.
@Anonymous,
Assuming you already remove the EXE_PATH per Mark's response, please search the Setup.ini file for VCREDIST2005SP1ATLX64 and delete it from the prerequisite sections throughout the file.
Once completed, run the installation again.
If this information was helpful, please consider using the Accept Solution
Message 19 of 19
This worked. Thank you so much. is there anything else i need to do with regards to microsoft visual 2005?
