Thanks, m.latz.
Before touching the registry we went through one more time and deleted everything Autodesk-related we could find, including some places not listed in the "clean uninstall" instructions.
Of course the install failed again, but this time it wrote several files to %temp%:
File Name Size
AutoCAD_2022_English_Win_64bit_dlm.sfx.log................................................244
adsk_dda_dlm.lock.........................................................................................................0
adsk_dda_ui.lock............................................................................................................0
AdODIS-install.log................................................................................................36,588
adsk_dda_im.lock...........................................................................................................0
adsk_dda_la.lock............................................................................................................0
adsk_dda_pl.lock............................................................................................................0
adsk_IPCUpdaterChannel.lock....................................................................................0
Autodesk_AutoCAD_Architecture_OE_2022_install.log...........................533,030
Autodesk_AutoCAD_Private_2022_uninstall.log............................................5,150
Autodesk_AutoCAD_Private_2022_install.log............................................198,396
Autodesk_AutoCAD_Architecture_OE_2022_uninstall.log........................36,838
utodesk_AutoCAD_LangPack_en-US_2022_uninstall.log.....................1,107,578
Autodesk_AutoCAD_LangPack_en-US_2022_install.log.......................1,740,432
Autodesk_AutoCAD_Core_2022_install.log.............................................14,802,146
Autodesk_AutoCAD_Core_2022_uninstall.log.........................................9,775,636
I browsed through them and in Autodesk_AutoCAD_Private_2022_install.log I found the following error listings:
1: LicensingCustomAction.licRegister [E] [12:09:38:750]: exit code: 100, output: (500)(error while saving feature:ENCODED{5pywJ/fogvXf8iX+iOlvnoYvdKdDYmm0+2/I8iZxJGxpiSTGUsqKT0xDvHPvVu/n77DZowxw/mzfMmNbfgG7v0Xysi+SFyXl+poxS5SpmhkPuwC1V23FNERHcQpycjtsJpjfpSfDjW5mCTB7wNQZuf+bKsNAfQaHYAjI5ptq89MqmFYKgm5APGg0Ni8fYqu+ChFuI/Y90pKCeg42e9NZYLvYvJZbFcjZ8AiO5/+BcO+PQ6oJtcVUyodgvbczUKUgfpCuJHpkVQKexCjPdcw7A+IQ+B1LBYs2spxONS9Fz1ha52lAcMEM1B0R24aD5ugh})
hint: might be caused by invalid feature for current pit file. Action ended Return value 3
1: LicensingCustomAction.licRegister [E] [12:09:38:750]: Registering a product with key 00000 and version 2022.0.0.F failed
CustomAction licRegister.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (74:B4) [12:09:38:774]: Error in rollback skipped. Return: 5
MSI (s) (74:B4) [12:09:38:776]: Note: 1: 2318 2:
MSI (s) (74:B4) [12:09:38:779]: Note: 1: 2318 2:
MSI (s) (74:B4) [12:09:38:779]: No System Restore sequence number for this installation.
MSI (s) (74:B4) [12:09:38:812]: Windows Installer installed the product. Product Name: ACAD Private. Product Version: 24.1.51.0. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
Is this what we are looking for? Some of these files are too big to paste or email, and I don't really know where I'm supposed to be looking.
Bruce
