Windows UAC error with Inventor 2025 after Windows August 2025 Update
pcmediaHXRXC
Observer Observer
pcmediaHXRXC
Observer
Observer
Having the same error occur with the UAC with long windows login times for users that is talked about  in this thread
https://forums.autodesk.com/t5/installation-licensing-forum/why-is-a-random-msi-running-for-standard...
Can anyone one advise when the MSP will be out for Inventor 2025 like Autodesk has just done for AutoCAD & Civil3D like in this link
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/After-installation...
TIA
johnsonshiue
Hi! If I recall correctly, the msp install may not be supported since Windows 11 no longer allows application updates to be uninstalled individually.
Many thanks!
Software Test Engineer
pcmediaHXRXC
Observer
Observer
Hi Johnson,
Thanks for the reply, hoping to sound not stupid, quoting you "the msp install may not be supported since Windows 11 no longer allows application updates to be uninstalled individually"
then how come there is a MSP for AutoCAD versions for Windows 11 in the second URL I supplied and users from the first URL I supplied say that it works?
Cheers
johnsonshiue
Hi! I am sorry I might have misunderstood the issue. Unfortunately, I am not an expert on product installation. I will move this thread to Install and Licensing forum. The experts there might be able to help.
Many thanks!
