Windows cannot find 'C:\Program Files\Autodesk\Revit 20xx\Revit.exe
Jroper
Jroper
Hello, I cannot get Revit 2023 installed on a user's computer. I've done a very clean uninstall and reinstall twice. I did a sfc /scannow for corrupted files. What windows component is not happy that this error message would pop up immediately?
Simon_Weel
Any errors during install?
mdavis22569
Hi @Jroper
have you seen the following Autodesk article about this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Windows-cannot-fin...
I'd also recommend the Microsoft Fixit Tool:
https://www.autodesk.com/support/download-install/individuals/manage/uninstall-autodesk-software
From there, I'd grab the offline installer for 2023 Revit from here and use that for the installation:
https://forums.autodesk.com/t5/installation-licensing/2023-product-download-links/m-p/11067891#M2618...
Mike Davis
Jroper
Thanks Mike,
I do use that Fixit tool quite a bit. The program was really stuck. I tried a very clean reinstall, but no luck. I've not used these direct download links before.
mdavis22569
Hi @Jroper
Not a problem... I'm a big fan of the direct downloads.
Mike Davis
