Announcements
Verify installed product with the command line
I'm looking for the best method of verifying and installed product in this case Freedom Viewer 2018.
Running the setup does not replace all the components from the original installation.
I see a setup folder in my INSTALLDIR, what is the syntax to run a repair?
Thank you,
Frank V.
natasha.l
Hello @Anonymous,
If you are trying to verify a successful installation the recommendation is to check your install log
Or you can run the C:\Autodesk\"Product Name" \Setup.exe it will run & check to see if the product & its components are installed.
Keep us posted on the progress you have made.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Thanks for that info,
I was looking for a way to run the setup.exe with Verify Flags a t the command line to run as part of the deployment. I can't seem to locate the proper syntax similar to the command line to install.
natasha.l
Hello @Anonymous,
I believe this can help you Options and Parameters installing from the command line. Otherwise you can locate this information through the deployment software you are using for better reference.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
