Vault Basic Server 2018 Installation SQL Server Connect Issue
Message 1 of 11
I am having a Vault Basic Server 2018 installation error appear when I try to install the software on our server and I have not been able to get it installed.
The error states: "Failed connecting to SQL Server" 'server=localhost\AUTODESKVAULT;userid=sa;password=*****"
The Autodesk SQL instance was configured per the information listed in the Autodesk Knowledge database.
The installation files were copied from the flash drive.
I am able to login to the instance on the server  with no issue and this is a single server single location application.
Also this is a brand new server that has never had the software installed on it before, any suggestions to resolve this issue?
Replies (10)
Message 2 of 11
DarrenP
try this: https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
DarrenP
Message 3 of 11
Jason.Courtemanche
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the Vault forum!
Please take a look at help article: Vault install error: Failed connecting to SQL Server.
I suspect that if you follow the first link to: Vault server install error: Failed connecting to SQL Server; Insufficient Permissions
  Copy the " SQLConnectCheck.exe" file from the  <Install_location>:\en-us\edmPrechecks folder into the  %temp% folder.
  (Note: Unless defined otherwise, the default location of %temp% is  C:\Users\<CurrentUserName>\AppData\Local\Temp\.)
Please, let me know if this fixed the issue if it did not work please post a screenshot of the error message you are seeing.
Jason
Message 4 of 11
Unforunately the command line looked exactly like the picture  on the link you sent. I even copied the SQLconnectcheck.exe to the %temp% folder.
I can login  to SQL through the SQL management Studio using the same password so I am not sure what is going on. I am using SQL Server 2012 service pack 3.
Below is the error I am seeing:
Message 5 of 11
DarrenP
check to see if the services is started
DarrenP
Message 6 of 11
Darren thanks for the link. Unfortunately that did not work either.
This is baffling me as to why it is not able to connect.
Message 7 of 11
DarrenP
there are other solutions in that link you may have to go through each one
DarrenP
Message 8 of 11
Neil_Cross
To save a lot of hassle, is it not worth uninstalling SQL, reinstall the instance and use the default sa password AutodeskVault@26200... and then just change the sa password through management studio after the install has succeeded?
Message 9 of 11
Neil I did uninstall the instance and reinstall as default password information. I ran the vault pre-check and it came back all passed this time including the SQL connect but when I went to install it same error occurred.  One weird thing happened when I went to login the SQL management studio I got an error I had never seen before but I clicked ok and tried logging again and it went fine so I am not sure what is going on. Utilizing the default password information did help but still not able to install.
Below is the error I got in SQL Management Studio:
Message 10 of 11
Jason.Courtemanche
Hi @Anonymous
This error only happens once then I would not worry about it as it happens when a connection is closed during the SQL login verification process.
Error:(A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.) (Microsoft SQL Server, Error: 233)
If you are still having the same issue please send me a private message so we can do a screen share and look at this further.
Send a message by hovering over my name jason.courtemanche and then select "Send a Message"
Jason
Message 11 of 11
Jason.Courtemanche
I wanted to follow up to close the loop on this issue. This was resolved by reinstalled SQL and copy the " SQLConnectCheck.exe" file from the  <Vault_Install_location>:\en-us\edmPrechecks folder into the  %temp% folder.
Jason
