Unable to update Identity Manager Program
thellums
thellums
AutoCAD Access says that Identity Manager has an update. I tried to update it but due to company policy rules, only admins in the IT department are allowed to install, upgrade, or update any software.
I have my own account with Autodesk but I am not sure that my company does since they only purchase licenses off shelf.
So what happens is:
IT clicks on the Update button. It prompts for a user/password login. Then it shows that it is downloading and then updating. It goes up to about 15% and then runs back down and finally says Failure.
Does the IT department need a Autodesk account to update this?
Any suggestions?
Simon_Weel
You need admin permissions to install it. So I guess you need one of the IT persons to do it for you, or they could grant you local Admin permissions to do it yourself.
thellums
Yes, I know I need admin privilege but our company does not allow this.
So any changes or additions/removals must be done by our IT department.
I had contacted them and they could not update the program even after logging in as Admin.
I also found out that our company does have an Autodesk account now so it should not be a account issue.
Yesterday, they went as far as removing and reinstalling Autodesk Access and updating the laptop BIOS.
Still no resolution.
Simon_Weel
Ok - don't use Autodesk Access; it has issues. Download the update for Identity Manager (see Option 3) and have the IT-person install it. Should be a matter of just running the installer. If there are any errors, please post those?
thellums
Thanks, I will pass this on to our IT department.
