Unable to install anything with downloaded installers and Autodesk Desktop App
marek.ledworowski
marek.ledworowski
Hello everyone
I was trying to install Autocad and Autocad LT but installation failed every time with code 70.
I tried removing all Autodesk repated keys in registry, files in appdata, temp, programdata and programfiles, disabling Windows Defender, updating Windows and reinstalling VC++ and .NET.
I also tried using all possible installation options (install/download).
This didn't resolve my issue, so I decided to install Autodesk Desktop App as standalone application. However when I log in, it shows I don't have a license for any product and software list is empty, which is weird because I use educational license.
Autodesk Licensing service was running at the time and restarting it didn't help either.
I feel like I'm in a dead end with this installation.
leowarren34
Hi @marek.ledworowski,
Have you followed the instructions here: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/autodesk-software-installati...
Run all installers as admin,
You can check which products you have at https://manage.autodesk.com/ under products and services.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
marek.ledworowski
@leowarren34 thanks for your reply. I have already followed this article at least three times with both online and offline installer.
leowarren34
Are you getting any errors when you install Visual C++ Redis on its own?
Leo Warren
marek.ledworowski
@leowarren34 None. On 1st try tried repairing installation, later tried uninstalling and installing again but to no avail. After "installation" I checked the logs and seems like AdskLicensing has a few bugs in service configuration scripts.
Btw this failed on both Win10 20H1 and 20H2.
marek.ledworowski
Problem solved.
Accessed products through https://manage.autodesk.com/ and downloaded AutoCAD 2020 instead of 2021. Installed flawlessly on first try.
