unable to initialize adlm + License was not obtained even though it its working
greekgooner
greekgooner
I am using Maya 2016. These 2 message, 'unable to initialize adlm' +' License was not obtained' ,  randomly appeared 2 or 3 times in the last few months.
My maya is working all fine. Not sure why this is happening. Will my Maya stop working all of a sudden? I have student 3 year version
Many Thanks
Otto
Hello greekgooner
It looks like you are unable to obtain a license from the server. The following article(s) should help you resolve the problem:
Can't obtain a license from the server
How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable
Troubleshooting FLEXnet Licensing Errors
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
greekgooner
So even though my Maya is definately working at this very moment...I am  using it right now to create a model...I still have to follow these troubleshooting steps?
natasha.l
Hello @greekgooner,
Use the following steps to reset the stand-alone licenses for all Autodesk products.
1. Close all running applications.
2. Rename the adskflex_#######_tsf.data file to adskflex_#######_tsf.data.old.
These files can be located:
Vista or Windows 7 /8 /10
  • C:\ProgramData\FLEXnet\adskflex_########_tsf.data
  • C:\ProgramData\FLEXnet\adskflex_########_tsf.data.backup
3. Launch the product & activate your Autodesk software
For student activation information review: Steps for Setting-Up Student Software
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
natasha.l
Hello @greekgooner,
Since it is working I wouldn't try to fix the pop-up error until after you are done using the software for your project. Wait until you don't need to use Autodesk product then try to troubleshoot it.
greekgooner
Ah yes, I presumed so as well. Thanks. As I have not followed the troubleshooting steps that you both kindly provided, I do not know if it has fixed my issue. So I will just accept you answer as the solution for now.
