Unable to download AutoCAD LT 2017
 Hi
I'm trying to download and install my seat of AutoCAD but it goes part way then errors.  I turned off the firewall to allow for it to install but still nothing. I'm running windows 10.  I was able to install the REVIT LT but not the library, but that is another issue.
thanks
lynn_zhang
Hi @Anonymous
Please also disable your anti-virus program (if any), and re-download the software from our Virtual Agent (click on Download Links, choose product and version). Then try the installation again.
Lynn Zhang
natasha.l
Hello @gaughan101,
As @lynn.zhang mentioned try installing via the Autodesk Virtual agent it is a more reliable method of download. To add to the information I have provided some steps that will help prepare your system for a successful download.
  • Log in as an Administrator
  • Temporarily disable your Antivirus software
  • Temporarily disable UAC
  • Download via the Autodesk Virtual Agent
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
If you continue to have an issue use:
AIDA Autodesk® Installation Diagnostic Assistant is intended to provide assistance in identifying the root cause and providing a suggested solution.
-Right click > Run as admin.
-Clean Temp Folder
Download Link:  http://www.autodesk.com/aida  > Select "Create Zip File"
Please keep us posted on your progress. Smiley Happy
