Unable to create Deployment for Building Design Suite Ultimate 2015
I'm trying to create a Deployment for Autodesk Building Design Suite Ultimate 2015. We're using a Licensing Server on the network. When I select the 'Network' License Type and enter the license server name, I cannot click 'Next' in the Deployment Wizard. The button stays greyed out. What am I missing here?
Otto
Hello c.dekker and welcome to the Autodesk community!
It looks like you're seeing a grayed out button when attempting to register and activate your product. This issue typically occurs because Internet Explorer is either blocking or cannot connect to Autodesk registration servers. Access to Autodesk services is blocked by either IE, network, or proxy server security settings. The following article(s) should help you resolve the problem:
Register Today (Product Activation Wizard) blank except for two radio buttons
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
You need to enter the serial number and product key for that product.
For help finding your serial number, please view the following video or use one of the links below to contact Autodesk:
If this doesn't work, please reach out to Autodesk Licensing and Activation team using one of the following:
If this information was helpful, please consider using the Accept Solution
