Unable to activate MAYA on ubuntu
I am trying to activate my student version of MAYA on my ubuntu 14.04, These are the problems I a facing:
1. Autodesk cant connect to internet so online activation is not working.
2. When I switch to offline activation it says that a request code has been generated in some file ....RegInfo.html (attached), but no request code is there and a file path is there ...LongCode.xml .
3. In that file also there is no field of request code.
(We need to submit this request code to get the activation code , but the request code itself is not generated :/). What should I do here
Otto
Hello gauravm043 and welcome to the Autodesk community!
It looks like you're seeing the Connect to Internet Error. This is due to a security upgrade Autodesk performed on our servers to mitigate the POODLE SSL 3.0 vulnerability. The following article(s) should help you resolve the problem:
Desktop Subscription customers get “Establish an internet connection to continue” error at login
Quick Start Guide: Setting up your Autodesk Desktop Subscription Software
Preparing your System for Installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
What version are you using? As described by Otto, you may need to install the Poodle hotfix.
if that doesn't work, please reach out to Autodesk Licensing and Activation team using one of the following methods:
    • Phone: (866) 681-4359
    • Chat: Online
If this information was helpful, please consider using the Accept Solution
No , the problem is still there 😕 ,  Version - Ubuntu 14.04 , MAYA = 2015 SP2
I tried the above poodle fix suggested (for connecting to internet) , but still MAYA is unable to connect.  I reinstalled MAYA, but again the same problem persists.
Another thing is I tried to manually install it but as stated in my question no request code is being generated (and for manual activation it seems I require that).
I tried contacting customer support for Licensing and activation two times via mail , stating my problem but as I can understand from their reply is that I need to generate request code somehow to manually activate MAYA (which seems impossible to generate from my side -- attached screenshot)
