Trouble with Install
Hi all, been having trouble installing Maya on my Win7. On the installer, I go straight to the "Componnts did not install correctly" Page, at which Maya and all of its related components are marked with a red X. I belive it to be a problem with Microsoft Visual C++ 2005 installing, but I am not savvy enough to figure it out. Here is the Log, thanks for any help!
015/12/17:13:23:23 David DAVID-PC === Setup started on DAVID-PC by David ===
2015/12/17:13:23:23 David DAVID-PC Path_Length: 143
2015/12/17:13:23:23 David DAVID-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2015/12/17:13:23:23 David DAVID-PC Launch
2015/12/17:13:23:23 David DAVID-PC CommandLine /PK 657G1 /SN 900-66589511 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2015/12/17:13:23:23 David DAVID-PC Current Directory C:\Users\David\AppData\Local\Temp\_AIF5D4.tmp
2015/12/17:13:23:31 David DAVID-PC === Setup ended ===
2015/12/17:13:23:24 David DAVID-PC === Setup started on DAVID-PC by David ===
2015/12/17:13:23:24 David DAVID-PC Path_Length: 143
2015/12/17:13:23:24 David DAVID-PC Current Directory C:\Users\David\AppData\Local\Temp\_AIF5D4.tmp
2015/12/17:13:23:24 David DAVID-PC Launch
2015/12/17:13:23:24 David DAVID-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2015/12/17:13:23:24 David DAVID-PC PageOpen LaunchDialog
2015/12/17:13:23:33 David DAVID-PC PageOpen LicenseDialog
2015/12/17:13:23:33 David DAVID-PC PageOpen ProductInfoDialog
2015/12/17:13:23:33 David DAVID-PC PageOpen ProductSelectionDialog2
2015/12/17:13:23:34 David DAVID-PC PageOpen FullProgressDialog
2015/12/17:13:23:35 David DAVID-PC Download Skipped VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2015/12/17:13:23:35 David DAVID-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\David\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/12/17:13:23:35 David DAVID-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Just saw the rule about not C+Ping Logs, but I think its short enough that it wont trigger the spam filter?
