Term has expired
Term has expired
Message 1 of 17
Term has expired
Hi, I am a hobbyist and use with a great pleasure Fusion 360 with a non commercial licence until a few days when "Terms has expired" appeared .I followed the procedure for registering again but it was unsuccessfull. I read the several reports about this issue in the forum and tried what was suggested in vain. After having uninstalled, re-installed, cleaned the cache,  moved on another computer I observed that the issue might come from my account.
I am blocked because I can't save any files on the cloud and I can't edit any DXF or STL files.
I should appreciate if you could help me. With my thanks.
Kind regards.
Jean-Jacques PONCIN.
I use the last version of Fusion 360 on a laptop with Windows 10.
Replies (16)
Message 2 of 17
Mark.Lancaster
@Anonymous
Have you gone into manage.autodesk.com and ensure that you have a new Fusion 360 term?
Mark Lancaster
Message 3 of 17
Yes I have just checked it again and I am confirmed having the last version of Fusion.
Message 4 of 17
Mark.Lancaster
@Anonymous
Can you tell me what you're seeing when you go to save your Fusion 360 files?
Mark Lancaster
Message 5 of 17
When I try to save the upper left icon remains faded and open only the information square Save Ctrl+S  Save a design to a located location..., but it doesn't open the main saving panel with the name of the file and the location.
Message 6 of 17
Mark.Lancaster
@Anonymous
Too me it sounds like you are in off-line mode.
In the clock icon upper right, if you select it..  Is on-line mode toggled (on)?
Mark Lancaster
Message 7 of 17
Yes I have checked that as well, I confirm I am on line.
Message 8 of 17
lena.talkhina
Hello @Anonymous !
Happy to see you on Autodesk Community Forums.
I would suggest to raise a tech support case from your Autodesk Account
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 9 of 17
Hello ,
Thanks for your message. As I had no solution and I really needed Fusion
for millig parts for my own use, I subscribed a licence for one month and I
recovered Fusion in its full capacity.
I will switch back to a non commercial licence in one month with the hope
of everything will keep on working normally. If not, I will report my issue
to a tech support. It seemed to me that a personal licence (hobbyist)
couldn't get a technical support, except from the forum.
Message 10 of 17
I am having the same issue.   I am a middle school stem teacher and have a full classroom of Inventor Pro licenses... but use fusion 360 at home to create lessons, projects, and print examples for kids.  Even with educator status, I can't get a version to work past the trial period.
Message 11 of 17
leowarren34
Have you requested access to Fusion from: https://www.autodesk.com/products/fusion-360/students-teachers-educators?mktvar004=668081&internalc=...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 12 of 17
yes, and on the autodesk site it says I was granted access. Yet, when I
open it on my computer i still says trial expired. trying again... also: I
cannot find the first version to uninstall before reinstalling... checked
both program files and user files... not showing up.
Message 13 of 17
Mark.Lancaster
@Anonymous
If you go into manage.autodesk.com and all products and services do you see your correct Fusion 360 there?
Update:  Also if your teach Inventor at school, why are you using Fusion 360 to plan the class?
Mark Lancaster
Message 14 of 17
ok, I think I've got it!  Thank you for your help
Message 15 of 17
nope.  Dont have it.  I successfully uninstalled, then reinstalled with proper auth.  Still opens saying Term Expired.
Message 16 of 17
Mark.Lancaster
@Anonymous
You never answered my question of going into manage.autodesk.com and all products/services..
Check that before you spend too much time with uninstalling/installing.
Mark Lancaster
Message 17 of 17
In my Manage products & downloads, I only see Render and Storage.  I have registered as an educator, and followed the prompt to download.   Still comes up trial expired.
I use fusion at home because our network at school cannot support cloud modeling.   I like to be up on the latest software, and can easily guide students in either program.
