Student license problems
Message 1 of 26
Hi there,
I just downloaded AutoCAD 2018 onto my Windows 7 PC, to be used for a class at college.  The download and installation went without issue, but I've run into a licensing problem.
My brother took the same class two years ago and used AutoCAD 2016 on this same computer.  The software was never removed from the computer, and when I went to begin using my 2018 copy, AutoCAD wouldn't let me in because "Your trial has ended." (see image below)  I have a separate account from my brother, so I don't understand why this is.  I need to get started on assignments soon, so this is fairly time-sensitive.
Can anyone help me please?
Thanks!
Replies (25)
Message 2 of 26
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Did you follow this https://forums.autodesk.com/t5/installation-licensing/steps-for-setting-up-student-software/td-p/682... to set up your student account.
Mark Lancaster
Message 3 of 26
No, I didn't use that sequence.  I don't recall receiving a serial number or license number.  I'm fairly certain I chose the "Install Now" option.
Message 4 of 26
lynn_zhang
Hi @cnormil0
Could you follow the instructions above to set up your student account? And you need to get a serial number from our Education Community to activate the software.
Lynn Zhang
Message 5 of 26
Thank you both for your help.
I don't think I was ever given a serial number in the initial setup, but I went back to the Education Community website as if I were going to download it again and was given my serial number.  I was able to input that into the program, and it let me in!  All seems to be working now!
Thanks again,
Christopher
Message 6 of 26
lynn_zhang
Hi @cnormil0
Glad to hear your student software is working now. Our pleasure to help you!
Lynn Zhang
Message 7 of 26
We're sorry we cannot provide you with your license details at this time.
We’re sorry, we cannot currently provide your license details.
We’re working to resolve this issue and will send you a progress update by email. Alternatively, you can try requesting your serial number again in 30 minutes.
Our apologies for this delay.
Any info about the given problem? Message keep appearing since several days
Message 8 of 26
Mark.Lancaster
@Anonymous
For this issue you have to run your product in 30 day trial until resolved.   But you have to reach out to the educational support team for this https://www.autodesk.com/education/support/edu-contact-us-form
In addition I have heard this is only impact those who are located outside the US.
Mark Lancaster
Message 9 of 26
I've got a similar problem. I've been trying to get a student license for a month now but to no avail. I already contacted Autodesk support. They said they are still working on it. I hope they fix it soon because I really need Autocad and Inventor for my classes.
Message 10 of 26
mcallistermark2023
Observer
Observer
I have students in my engineering class that have done the completed the educational access process and have received an email saying that they have an educational license but when they log into Fusion it still says they are expired. I teach in a computer lab that already has Fusion loaded. Please help.
Message 11 of 26
I have just renew my student lincense for autocad but when I open my autocad it still says I have two days remain to use and then when I click to activate says that my lincese right but my home use lincense has expired... I have no idea how to renew thar lincese, I thought I only had the student lincese. Please help
Message 12 of 26
leowarren34
Hi @mcallistermark2023,
Have they requested Fusion from the Education portal?
https://www.autodesk.com/education/edu-software/overview
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 13 of 26
leowarren34
Hi @Anonymous,
Which version of AutoCAD are you using?
What date does your educational access expire? https://www.autodesk.com/education/edu-software/overview
Leo Warren
Message 14 of 26
c.p.eskov
Observer
Observer
Hallo,
i tried to install Inventor with student licence serveral times. but when i start Inventor i run in error: your licence are expired".
I am registered as student. After upload a picture from my student card i was verified quickly.
i was beginning with unistall all old/other Autodesk stuff.
I downloaded and installed the Version over the website as logged-in-student and also tried to install over the Autodesk Deskopt Software.
All ways end in "no licence errors" when start inventor.
I never could enter a seriel  number. i wouldn't know where to find such serial number.
thx in advance!
Message 15 of 26
leowarren34
Hi @c.p.eskov,
Serial numbers are no longer used. Instead you just sign in with your Autodesk ID.
Make sure you have an Inventor license, by checking products and services at https://manage.autodesk.com/
You can get an Inventor license by running the download here: https://www.autodesk.com/education/edu-software/overview
You can disregard the installer.
Leo Warren
Message 16 of 26
c.p.eskov
Observer
Observer
Thank you for your answer.
By checking https://manage.autodesk.com/ i saw only a licence for Revit.
as i wrote before i was checking https://www.autodesk.com/education/edu-software/overview at first.
If i understand you correctly, to get a licence it could be enough to download the installer without running it?
Or have i to run the installer? What is with re still installed version? Do i need to remove the fresh but not running Inventor 2019 installation?
Message 17 of 26
c.p.eskov
Observer
Observer
the procces is complicated or not very user-friendly.
i got the licence by clicking on download on https://www.autodesk.com/education/edu-software/overview.
Now, https://manage.autodesk.com/home/ shows me the licence.
But either the still installed version of Inventor Pro 2019 (still no licence error) nor the downloaded installer.exe from https://www.autodesk.com/education/edu-software/overview start.
i have to tell you that in the meanwhile of this complications, i start testing solid edge from siemens. it was easy to download its studentversion and get it running. It seems to be not bad and with good performance.
I think your procces let me be tempted to test those other software.
Actuelly, i still can't use Inventor Pro 2019
Best regards!
Message 18 of 26
c.p.eskov
Observer
Observer
ok i see, that the installed version is 2019 (i was able to download it from your website as loged in user).
My licence seems to be for the 2022 version.
The new downloaded Inventor_Pro_2022_English_Win_64bit_Dlm_001_003.sfx from https://www.autodesk.com/education/edu-software/overview
return error (some like missing files).
I will give it last try by installing from https://manage.autodesk.com/products/invprosa.
Message 19 of 26
leowarren34
Hi @c.p.eskov,
You can get licenses from the portal dating back and including the 2019 version. Just make sure the license you have matches the install.
If you choose to use the browser download (multipart) you will need to disable your pop up blocker on browsers such as Chrome, you should get 3 parts.
If you want the 2019 Version, just select 2019 on the drop-down:
I agree that the process could be easier but it's what we have now.
Leo Warren
Message 20 of 26
soha.paryani1
I am having the same issue. I've installed AutoCAD 2023 on my computer and it says my student license is valid until June 2023, yet after installation I open the software and it displays that my subscription is no longer valid. However I have renewed my license and it says I'm eligible.  I did not receive any serial number etc. as well even though I followed all the steps and have student eligibility.
Please let e know how to solve this issue.
