Student license doesn't work with the last version 2020.1
Message 1 of 22
Hello everyone, have you experienced the same issue as me with the educational license when you updated to the 2020.1 version? How can it be solved?
thanks
Replies (21)
Message 2 of 22
I'm guessing your post was relocated here from a product-specific forum, so I'll have to ask...
What product?
Message 3 of 22
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I believe you are referring to InfraWorks 2020.1, correct?
I haven't heard of any other case where a student license stopped working after the update.
As a first troubleshooting step, delete file loginstate.xml in path C:\Users\<<USER>>\AppData\Local\Autodesk\Web Services.
Did that help?
Karsten.
Karsten Saenger
Message 4 of 22
Are educational licenses also available as the multi-user type? If so, could it be that their license file needs updating to include the Infraworks product code?
Message 5 of 22
Karsten.Saenger
Autodesk Support
Autodesk Support
@Anonymous , as far as I know student licenses are only individual single user licenses.
Karsten Saenger
Message 6 of 22
leowarren34
@Karsten.Saenger Second that, the only way to get site/institution licenses is through IT support role, and if they havent changed anything then Teacher.
@Anonymous I have had no issues with Inventor and many of the CAD apps. Have you updated the licenser?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 7 of 22
DarrenP
you don't actually say what problem your having nor do you say what product your even talking about
DarrenP
Message 8 of 22
The issue is about infraworks 2020.1. My license is valid and did not change since about one year. Also it work perfectly with the other softwares I installed.
Actually it worked until the last update with IW too
Message 9 of 22
DarrenP
what is the issue?
you still haven't said that
you just said it worked with the last update
what does this mean?
what worked?
DarrenP
Message 10 of 22
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I think I have found the explanation for your issue in a FAQ info:
"I’m using an Educational (EDU) license, am I affected?
Educational licenses for InfraWorks (2020.1) are not available for single-user or multi-user access at this time."
So, the solution for you is to wait a bit until student licenses are supported for InfraWorks 2020.1 or re-install version 2020.0.
Karsten.
Karsten Saenger
Message 11 of 22
ok, so that's the problem...
thank you for your help and kindness.
Message 12 of 22
Karsten.Saenger just wrote me that "Educational licenses for InfraWorks (2020.1) are not available for single-user or multi-user access at this time."
thanks anyway
Message 13 of 22
maja_abdihodzic
Hi @Karsten.Saenger,
I have the same problem with infraworks 2020.1, but i edited some of the models in that version and upgrade them to that version. ( Did not assign the licence, I just continued to work in trial version).
Now I am affraid to re-install 2020 version of infraworks bcs of that models. I think that I will not be able to work in that models in version 2020.
Do you have any suggestion?
Best Regards,
Maja
Message 14 of 22
lonelanrete
I cannot revert back to 2020.0
I already clean uninstall Infraworks 2020.1: program files, program data, user data, registry editor, etc
but when i tried to install 2020.0 it says: "newer language pack already installed"
and failed to install
did i miss something? where is this language pack to be uninstalled?
Message 15 of 22
Mark.Lancaster
@lonelanrete
Have you tried Microsoft Fixit?  https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-instal...
Look for related language pack in the uninstall program list.
Mark Lancaster
Message 16 of 22
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @lonelanrete ,
I had similar problems uninstalling InfraWorks on one computer.
It finally worked after removing everything InfraWorks related via Windows Programs and Features menu. Then use Microsoft FixIt and clean everything that is still listed. After that, search your Autodesk Program Files and Program Data folders for InfraWorks Files and folders that might still be there.
Finally, open the registry and remove everything under Autodesk InfraWorks in HKEY_CURRENT_USER\Software\Autodesk\ and HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk.
Once done - try to install the older version.
Karsten.
Karsten Saenger
Message 17 of 22
lonelanrete
already found the solution
need to search "infraworks" in registry editor and remove them. there are 2 registries for this infraworks language pack and content pack that is separated from Autodesk registry
Message 18 of 22
lonelanrete
recently just out infrawork 2020.2
does it work with student license now?
Message 19 of 22
banufenufawa
Seriously? 2020.1 is still a problem let alone 2020.2?... I am just saying, Sir...with all due respect. We just have to wait as mentioned above.
Message 20 of 22
leowarren34
At this rate 2021 will be out so hopefully that's an option to those who need infraworks.
Leo Warren
