@Anonymous
How has the software been installed? Install now? Has the actual software media actually been downloaded to the machine?
Here's what I would recommend...
Perform a clean uninstall per these instructions. Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine.
Download and install per:
1. Clean out your personal temp (%temp%) folder. Make sure you have full admin rights, set Windows UAC to never notify and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. This means save each part to your hard drive. Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product. At this point you could cancel the installation or create a deployment.
Good luck and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
