My instalation is failed and that's de log arquive:
2017/4/6:17:23:14 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/4/6:17:23:14 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/4/6:17:23:14 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AI80B3.tmp
2017/4/6:17:23:14 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/4/6:17:23:15 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/4/6:17:23:15 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/4/6:17:23:15 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AI80B3.tmp\Setup\AcSetup.dll
2017/4/6:17:23:15 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/6:17:23:15 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/4/6:17:23:25 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/4/6:17:23:25 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/4/6:17:23:25 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/4/6:17:35:15 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/4/6:17:35:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/4/6:17:35:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/4/6:17:35:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/4/6:17:35:16 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/4/6:17:35:22 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/4/6:17:35:22 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/4/6:17:35:22 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/6:17:35:38 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Succeeded
2017/4/6:17:35:38 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/4/6:17:35:38 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/6:17:35:49 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/4/6:17:35:50 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/4/6:17:36:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/4/6:17:36:16 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/4/6:17:36:25 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/4/6:17:36:41 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback Autodesk Material Library 2016 Succeeded
2017/4/6:17:36:41 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/4/6:17:36:43 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/4/6:17:36:52 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjvrXQAR /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:08:58:08 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AI4FBF.tmp
2017/5/12:08:58:45 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:08:58:09 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:08:58:09 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:08:58:09 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AI4FBF.tmp
2017/5/12:08:58:09 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:08:58:10 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:08:58:10 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:08:58:11 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:08:58:44 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:08:58:44 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AI4FBF.tmp\Setup\AcSetup.dll
2017/5/12:08:58:44 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:08:58:45 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:08:59:01 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:08:59:01 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:08:59:58 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:00:02 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:00:02 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:00:02 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:00:03 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:00:08 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:00:08 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:00:19 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:00:19 Elisabete Fontinha DESKTOP-7VBDQ1O Download Play CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:00:35 Elisabete Fontinha DESKTOP-7VBDQ1O Download Complete CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:00:35 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:00:39 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:00:42 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2017/5/12:09:00:42 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/5/12:09:01:03 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjvrXQAR /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:09:01:49 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIB2B0.tmp
2017/5/12:09:01:53 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIB2B0.tmp
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AIB2B0.tmp\Setup\AcSetup.dll
2017/5/12:09:01:51 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:09:01:52 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:09:01:58 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:09:01:58 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:09:03:08 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:03:10 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:03:10 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:03:10 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:03:10 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:03:20 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:03:20 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:03:20 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:03:23 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:03:26 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2017/5/12:09:03:28 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/5/12:09:04:47 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjvrXQAR /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:09:05:14 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AICDFA.tmp
2017/5/12:09:05:18 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AICDFA.tmp
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AICDFA.tmp\Setup\AcSetup.dll
2017/5/12:09:05:16 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:09:05:17 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:09:05:28 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:09:05:28 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:09:05:49 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:05:56 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:05:56 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:05:56 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:05:56 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:06:04 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:06:04 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:06:05 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:06:08 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:06:11 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2017/5/12:09:06:12 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/5/12:09:06:51 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjvrXQAR /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:09:08:34 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIDF32.tmp
2017/5/12:09:08:40 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIDF32.tmp
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:08:35 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:08:36 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AIDF32.tmp\Setup\AcSetup.dll
2017/5/12:09:08:36 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:09:08:37 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:09:09:02 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:09:09:02 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:09:09:46 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:09:59 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:09:59 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:09:59 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:09:59 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:10:08 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:10:08 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:10:08 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:10:11 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:10:14 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2017/5/12:09:10:16 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/5/12:09:10:27 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjvrXQAR /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:09:16:18 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIF335.tmp
2017/5/12:09:16:23 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AIF335.tmp
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:16:19 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:16:20 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AIF335.tmp\Setup\AcSetup.dll
2017/5/12:09:16:20 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:09:16:21 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:09:16:34 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:09:16:34 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:09:17:55 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:17:58 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:17:58 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:17:58 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:17:58 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:18:06 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:18:06 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:18:06 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:18:09 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:18:12 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2017/5/12:09:18:14 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen InstallCompleteDialog
2017/5/12:09:19:18 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O CommandLine /akamai /sid a1b3A00000AjwQ2QAJ /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_S..."
2017/5/12:09:31:01 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AI6D96.tmp
2017/5/12:09:31:06 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup ended ===
2017/5/12:09:31:04 Elisabete Fontinha DESKTOP-7VBDQ1O === Setup started on DESKTOP-7VBDQ1O by Elisabete Fontinha ===
2017/5/12:09:31:04 Elisabete Fontinha DESKTOP-7VBDQ1O Path_Length: 154
2017/5/12:09:31:04 Elisabete Fontinha DESKTOP-7VBDQ1O Current Directory C:\Users\ELISAB~1\AppData\Local\Temp\_AI6D96.tmp
2017/5/12:09:31:04 Elisabete Fontinha DESKTOP-7VBDQ1O Launch
2017/5/12:09:31:05 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:31:05 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP...
2017/5/12:09:31:05 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ELISAB~1\AppData\Local\Temp\_AI6D96.tmp\Setup\AcSetup.dll
2017/5/12:09:31:05 Elisabete Fontinha DESKTOP-7VBDQ1O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/5/12:09:31:05 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LaunchDialog
2017/5/12:09:31:12 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen LicenseDialog
2017/5/12:09:31:12 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductInfoDialog
2017/5/12:09:31:51 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen ProductSelectionDialog2
2017/5/12:09:31:53 Elisabete Fontinha DESKTOP-7VBDQ1O PageOpen FullProgressDialog
2017/5/12:09:31:53 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/START...
2017/5/12:09:31:53 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIREC...
2017/5/12:09:31:53 Elisabete Fontinha DESKTOP-7VBDQ1O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/5/12:09:32:05 Elisabete Fontinha DESKTOP-7VBDQ1O Install DirectX Runtime Succeeded
2017/5/12:09:32:05 Elisabete Fontinha DESKTOP-7VBDQ1O Download Skipped CM http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.ta...
2017/5/12:09:32:05 Elisabete Fontinha DESKTOP-7VBDQ1O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/5/12:09:32:09 Elisabete Fontinha DESKTOP-7VBDQ1O Install Autodesk Material Library 2016 Failed Installation aborted, Result=1618
2017/5/12:09:32:12 Elisabete Fontinha DESKTOP-7VBDQ1O Rollback DirectX Runtime Failed Failure is ignored, Result=1618
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
