Slow Startup
Slow Startup
Slow Startup
Hi ,
I am having problem with revit 2017 super slow startup. It takes about 80 to 2 minutes for program to start.
any solution ?
I have Xeon CPU with 32 GB Ram and 256 GB of SSD storage.
thanks.
Mark.Lancaster
@Anonymous
@Anonymous wrote:
Hi ,
any solution ?
thanks.
80 minutes or 80 seconds?
What type of license do you have?   A commercial license or a student license?   If its a commercial license what type is it?  Perpetual on a maintenance plan or term based?
Mark Lancaster
its a commercial license , 1 year subscription.
journal file also attached.
80 second to 2 minutes
thanks.
Mark.Lancaster
@Anonymous
I'm not a Revit user but is the slow startup occurring on the splash screen or after the application is open and you are trying to load a project?   If on splash screen it may be loading slow due to checking license.  If this is the case what happens if you disconnect from the internet.
Mark Lancaster
once I disconnected from the internet , it started quickly. So, is this normal you think ?
Mark.Lancaster
@Anonymous
There has been some known issues lately about checking license taking some time to complete.  It may have to deal with the latest Windows 10 version.  @mdavis22569 can you confirm because you were seeing a lot of delays lately.   So when you disconnect, its not checking the Autodesk servers to see if your subscription is still active.   You can run it like that for 30 days.
Mark Lancaster
thanks Mark.
