- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning,
As an Academic Resource Centre customer, we've downloaded the Autodesk T-Splines plugin for Rhino 5, and obtained the network licence and serial number, which is all activated and running on our Autodesk network licence server.
However, the installer for the T-Splines plugin appears to have some issues.
- The option for creating a deployment appears to be missing
- Attempting to run the MSI install within the setup package comes up with an error "Cannot access network location INSTALLDIRadlm" - this even happened running command prompt as an admin and launching MSIEXEC with the same paramaters
- If you do perform an install using the setup.exe and run as an admin user, uninstall also fails with the same error as above because it's attempting to uninstall the same MSI that setup has for some reason.
I tried the version from Academic Resource Centre and the installer from the T-Splines website, both came up with exactly the same errors.
I've also tried to run the setup with a series of switches to batch install an Autodesk product, something like:
setup.exe /t /qb /language en-US /c TSPLINESPLUGINX64: INSTALLDIR="%ProgramFiles%\Autodesk\T-Splines for Rhino" ACADSERIALPREFIX="XXX" ACADSERIALNUMBER="YYYYYYYY" ADLM_PRODKEY="A46G1" ADLM_EULA_COUNTRY="en-US" InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="serveraddress 000000000000"
This only appears to work if running as a user with admin rights, not for example if as a system user, so deployment with either SCCM or Zenworks would prove to be incorrect. Also an uninstall would still fail for the same reason as above.
Is there any way the installer can be checked and possibly a solution found?
Regards
Warren.
