Serial number and product key of Autodesk Autocad & Revit 2023
ronalddinesh05
Observer Observer
ronalddinesh05
Observer
Observer
Hi Sir,
I'm a BE Civil Engineer and start a new business. So, how to get a serial number and product key of Autodesk Autocad & Revit 2023? Pls, find a solution and get a access key sir.
handjonathan
Hi @ronalddinesh05
Thanks a lot for posting your question to the forums!   Autodesk has moved away from serial numbers and uses a named user model for licensing. More information on this can be found here.
If you need to purchase a subscription, you can browse the product library here.
Jonathan Hand
Technical Marketing Manager | Construction
rushabhthakkar_910
@ronalddinesh05,
As @handjonathan said, now you don't need any Product ID or Serial numbers. Now you need to Login to the software with your Email Id and password. and it's done.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
mdavis22569
@rushabhthakkar_910 good thing you confirmed what Jonathan posted ...
Mike Davis
