公告
Security System (softlock licence manager) not functioning
jlo2009
2,328 次查看
3 条回复
1 条消息(共 4 条)
jlo2009
Sudenly I am getting this error message when I try to start any AutoCAD products.
The security system (softlock licence manager)
is not functioning or is improperly installed.
This happens with all products in Infrastructure Design Suite Premium 2014.
None will start.
Has anyone come across this before?
Tried a complete install of 2015 yesterday and got all products working but today the error message is back
Win 7 64 bit PC.
0 个赞
已接受的解答 (1)
2,329 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
Otto
Hello jlo2009
It looks like you're getting a Softlock License Manager error. This error can have several causes. The following article(s) should help you resolve the problem:
Launching program results in Softlock License Manager error
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
0 个赞
3 条消息(共 4 条)
jlo2009
Further to my initial post I meant to add that I am running a Network Licence versiion of IDS and not stand alone licence.
No other users who access the same Licence Manager are experiencing the same issue.
Any clues?
Thanks.
0 个赞
4 条消息(共 4 条)
jlo2009
已接受的解答
Solution:
Issue was with productinformation.pit file.
http://forums.autodesk.com/t5/installation-licensing/what-is-the-productinformation-pit-file-amp/m-p...
This file was missing from c:\programdata\autodesk\adlm
A copy of the file from another PC with the same products installed was copied over to my PC and the PC re-started.
0 个赞
