Script error when trying to use license transfer ACAD 2014 permanent.
smed1
Observer Observer
smed1
Observer
Observer
Moving from a quite old PC to a brand new one but can’t export the license due to “An error has occurred in the script on this page.”
Line 10
Char 14854
Error Expected identifier
Code 0
URL https://accounts.auto desk.com/logon?resume etc
I need to be able to use ACAD on the new PC.
mdavis22569
So if you're on a new PC likely it's not going to work.
AutoCAD 2014 isn't suppported on Windows 10 nor 11
If you get it (be cautious of the c++/net updates) try activating it via
https://www.autodesk.com/support/download-install/individuals/product-key/determine-whether-you-need...
2014 system requirements:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
Mike Davis
smed1
Observer
Observer
Thanks for getting back to me so quickly.
My issue isn’t with the new PC (the trial version seems to be working OK, at least for now.)
My current problem is releasing the license from the old PC.
Kind regards,
Steve
mdavis22569
What iOS?
And the licensing transfer won't work on the newer.
What happens if you try and activate it with your Serial Number and Product key?
As mentioned you might need to do it manually.  However I'd be careful if you're on W10 or W11. I see it a lot ... crashing and corrupting of the files.
Mike Davis
